Pottery Wheel Project
Forum topic by Harry_Ch posted 07-23-2013 01:25 AM 1097 views 0 times favorited 6 replies Add to Favorites Watch
View Harry_Ch's profile
Harry_Ch
63 posts in 2672 days
07-23-2013 01:25 AM
Has anyone out there uses or built a pottery wheel? Looking to build a kickwheel style pottery wheel, because the user can use it anywhere they want. From the plans I have seen, the build is straight forwards with a few twists and turns, but nothing to seriously put a kink into it. Not too crazy about making the kicking wheel out of cement, so going to build a hollow wood wheel to fill wil lead or sand.
Thanks for the input and hope to have it done before too long. After that, maybe the kiln to get rid of all the scraps and sawdust that I’ve been collecting on.
-- Deeds not Words.
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3709 days
#1 posted 08-29-2013 03:33 AM
Would the sand or lead (I am assuming lead shot and not poured lead) dampen the feel of the wheel somewhat, I thought the advantage of the concrete was the monolithic stiffness and ‘feel’ you get from the stiffness.
Harry_Ch
#2 posted 08-30-2013 04:11 AM
Should have mentioned the wheel would be divided in four sections with individual fill holes for the lead shot or sand. Since there will be little room for slop, that should ensure a proper feel to the wheel.
-- Deeds not Words.
Mark Shymanski
#3 posted 08-30-2013 07:10 AM
It will be interesting to see this wheel when you have it complete. Do you throw pots already or will you be learning with this wheel. I understand it takes considerable skill not over speed the wheel, control the clay while kicking and not falling over :-) I wish you success on this project and very much look forward to pictures or even a video of it in action!
View bannerpond1's profile
bannerpond1
397 posts in 1895 days
#4 posted 08-30-2013 02:16 PM
I’ve done quite a bit of throwing on a potter’s wheel. Making the kick wheel is going to be a real challenge, because you are going to have to balance that sucker or the whole shebang will wobble and vibrate. Maybe you could buy a heavy iron wheel of some sort that would give you a headstart. I cannot imagine trying to balance a homemade wheel. Perhaps a replacement kickwheel from a manufacturer?
Personally, I’d buy a used wheel and not go to the trouble.
-- --Dale Page
Mark Shymanski
#5 posted 08-30-2013 11:01 PM
How about a large flywheel from an old tractor? Would a 24” wheel be too big?
View JustJoe's profile
JustJoe
1554 posts in 2034 days
#6 posted 08-30-2013 11:07 PM
How about a large weight from a barbell set?
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
