Building a pentagonal box
Forum topic by lumberjocksmjc posted 07-22-2013 06:34 AM 1398 views 0 times favorited 15 replies Add to Favorites Watch
View lumberjocksmjc's profile
lumberjocksmjc
2 posts in 1968 days
07-22-2013 06:34 AM
Topic tags/keywords: garden boxes pentagon boxes complex cuts for boxes
I’d like to build a pentagonal box with sloping slides; top is larger than bottom. Anybody know where to find a plan? And where to learn how to make the complex cuts for the corners of the box?
Thanks in advance for any help.
Mike
15 replies so far
View Buckethead's profile
Buckethead
3194 posts in 2065 days
#1 posted 07-22-2013 09:13 AM
360°/ 5 = 72° the angles created at each panel joint.
72°/2 = 36° the two bevels needed to create the angle.
You’ll might also need to bevel the top (and bottom) edges of each side. That bevel will change depending on what angle (miter cut) you decide on for each side. More angle (obviously) will result in a greater difference in the top and bottom perimeters, as well as a need for more bevel. I don’t know how to mathematically determine what that top bevel would be. I would use a dry fit to see what angle is measured between the table and the box (perpendicular to the face of a panel) and apply that same angle to your top bevel cut.
-- Support woodworking hand models. Buy me a sawstop.
Buckethead
#2 posted 07-22-2013 11:21 AM
While commuting to work, I thought about this again. What I said above only works at 90 degree miters. As the angle of the miter cut increases, the bevel will decrease. So my above post is inaccurate.
I think I figured it out though.
If the panel is oriented at 90 degrees to the table, the bevel is 36 degrees. If it is lying flat on the table ( forming a flat surface) the “bevel” is at 0 degrees. The range of change is 90 degrees.
If you oriented the panel at 75 degrees to the table you would need 75/90 of your 36 degree bevel. 36x.833=29.88 degrees.
I’m not sure this is right. Thinking on the fly here. I know there is someone who knows the proper formula here, but it is fun trying to picture the solution in my mind.
View StLouisWoodworker's profile
StLouisWoodworker
67 posts in 4173 days
#3 posted 05-12-2016 01:52 AM
Specify number of sides (5) and the slope of the sides (degrees from horizontal). Then
see http://dls-website.com/documents/WoodworkingNotes/CompoundAngleJoinery.pdf
for the formulas to determine blade tilt and miter-gauge angle to make the cuts.
-- Don Snyder (38.6N, 90.3W)
View AZWoody's profile
AZWoody
1413 posts in 1421 days
#4 posted 05-12-2016 02:21 AM
The sum of degrees in a pentagon is 520 degrees, not 360.
Don’t know why I remember that from geometry but for some reason that stuck in my noggin.
The processes to figure the angles and do the maths listed in the previous link, not so well, haha.
View jbay's profile
jbay
2858 posts in 1096 days
#5 posted 05-12-2016 02:47 AM
I use this calculator.
I just use one of the side angles as the wall, and the degree of slope for the spring angle.
Takes a little playing around but it will get you there.
View splatman's profile
splatman
586 posts in 1596 days
#6 posted 05-12-2016 03:21 AM
Build a thingamajig to hold your stock at the desired slope. Then you only need to cut the miters at 36° No compound miter acrobatics needed.
View shipwright's profile
shipwright
8162 posts in 2995 days
#7 posted 05-12-2016 05:13 AM
View ArtMann's profile
ArtMann
1132 posts in 1013 days
#8 posted 05-12-2016 03:55 PM
Here is another calculator that is a little more straightforward.
http://www.pdxtex.com/canoe/compound.htm
View waho6o9's profile
waho6o9
8516 posts in 2774 days
#9 posted 05-12-2016 04:24 PM
Gary Katz has a great tutorial on tapered columns.
http://www.garymkatz.com/trimtechniques/tapered_columns.html
View helluvawreck's profile
helluvawreck
32087 posts in 3063 days
#10 posted 05-12-2016 05:12 PM
Turbocad Deluxe is an easy to learn CAD program that is really powerful for the price. You can use it to make all sorts of drawings to answer calculations like that. I used it in our molding plant for years. I had a machine shop in the plant and also made the templates for the molder tooling. It wasn’t as powerful as AutoCAD but it was plenty powerful enough.
helluvawreck aka Charles
View tomsteve's profile
tomsteve
869 posts in 1416 days
#11 posted 05-12-2016 06:43 PM
Don t know why I remember that from geometry but for some reason that stuck in my noggin.
- AZWoody
i think its 540 degrees
tomsteve
#12 posted 05-12-2016 06:44 PM
View darinS's profile
darinS
713 posts in 3064 days
#13 posted 05-12-2016 07:08 PM
tomsteve is correct. Interior angles add to 540° (sum of interior angles [n] = (n-2) x 180° so (5-2)x180 is 3×180=540
-- They say many people die because of alcohol. They never realized how many of them are born because of it.
View Jim Finn's profile
Jim Finn
2686 posts in 3119 days
#14 posted 05-13-2016 12:41 AM
I have found that when making a flared box like this if the flare is 5° or less it can be ignored. Over that 5° it will make a difference in the miter angle required.
-- No PHD just a DD214 Website> craftingcouple.com
AZWoody
#15 posted 05-13-2016 01:03 AM
- AZWoody
- tomsteve
Yup, that was a typo on my part.
