I'm sure this question has been bandied about ad nauseum, but I have to ask: how much dust collector do I need? I was looking at the PC400AP at Lowes. I hear people saying to avoid the 1 HP units, and I will do that if necessary, but…here is my situation:
1. never using more than one tool at a time (unless you count the dust collector)
2. all my tools - table saw, miter saw, router table - have 2 1/2" fittings
3. I'm really short on space, and would have to run 220 if necessary
Like I said, I'll go bigger if it's really necessary, but…in the opinion of the wise LJ folks…how much do I really need?
I'm sure this question has been bandied about Oh, maybe once or twice LOL. Do a search on the site here and you'll see a conversation or 2 on dust collectors )
I bought a Harbor Freight 2 hp unit a few months ago and hooked up a cyclone to it. It works/runs well and gets 99% of the saw dust, but does not catch allot of the real fine dust due to the 5 micron bag (5 microns is bigger than some might think). What ever you decide on, you'll likely want a 1 micron or less bag/filter.
If you leave the 2 1/2" fittings on your tools, I'd say you need to skip the DC and just buy a vac. Most DC's can pull ~400 CFM through 4" pipe, reduce it to 2.5" and you get pretty much nothing useable. So, if you don't want to upsize those ports, having a DC isn't going to do much to improve your life…..I probably didn't mean that to sound as harsh as it might; but I'm big on good DC.
I use my HF DC for my table saw right now. It's the only thing I have hooked up and really the only thing I need hooked up. The miter saw has a hood and the band saw doesn't aerate dust. It's the sanders that cause a problem in my shop and I've not found a way to DC those and still be able to use them.
A shop Vac with a Dust Deputy upstream is really all you need for the tools you have. Mine could keep up with my planer but the bucket filled quickly with chips. Mount the DD on at least a 10 gallon drum and you should be OK. Right now, my miter saw is the only thing hooked to it. No problem with the bucket filling too fast.
Google "Dust Deputy". It works great because the vac stays empty and everything else goes into the bucket/drum.
Lots of folks on here have posted in many threads about dust collection. So git-to-searchin'!
I have a 1hp DC that I use between the planer and bandsaw. I just move the hose between the two machines. For single machine applications like that, it does work fairly well. My shop layout didn't help too well with moving the DC to the jointer and TS. I ended up getting the HF 2HP and dedicated it to those two machines. I will eventually run another branch to the router table (once I build a new one, that will have a 4" hook-up) and the OSS Sander (right next to the router table) The OSS has a 2.5" connector. What I have heard is, if possible, run 4" hose right to the machine and the reduce at the point of hookup. This will give you the best chance of it grabbing the dust from the machine.
One element I didn't mention: I can (and intend to) move whatever tool I'm using right next to the DC unit, so I won't have a long hose reducing the suction power.
Fred: the ports on the saws are integral and can't be replaced, though I could put a 4"-2.5" adapter on them. Would that make a difference, or is the 2.5" bottleneck a deal-killer?
The Dust Deputy is intriguing. Anyone else have an opinion on them for my particular use model?
I have a 1HP unit and it keeps up with planner and tablesaw. It has problems dealing with the jointer. Also, the flexible tubing that I use to go from machine often results in the chips bunching up and clogging the whole thing in front of the wye.
If I had the circuits in my shop, I would definitely go for 2HP to get at least 1100 CFM. My 1Hp does 650CFM and its not enough.
I started with the C-man version of this back when it was $100. I have used it for at least 10 years until I built my 3Hp cyclone. It performed great for chip collection. In order to keep the shop clean, but left the fine dust behind. I think if you are moving it around it is the best way to go with the dust right hose. it will have the same power as the PC but it is way more compact and portable. I would also recommend a top hat separator for ease of emptying.
I often see folks mention they can't replace ports to upsize them. I would do whatever it takes to make them larger…at least if you want to capture dust. That might mean cutting holes, replacing parts, or in many cases it may be easier, ,most jointers only require replacing the plastic flange on them. My drum sander had a 4" port on the hood, and that wasn't enough (for me) I took the hood off and cobbled together a complete replacement so I could have a 6" port. Ain't pretty, but man; does it work good!
Best bang for the buck is the HF 2hp unit. It runs on 120v, but needs a 20amp breaker. Cost about $140 with a coupon from a wood working magazine.
Ditto on enlarging the ports.
The next best method, and the only workable choice if you don't want to enlarge the ports is a big shop vac. The shop vac will work alone, but having a inline drop out box or cyclone is a great accessory to make the vac better.
I have a 1 HP Dayton DC that handles most of my dust Cabinet saw and planer. I have a Ridgid 6HP,14 gal shop
vac pulling through a Dust deputy that handles my 6" jointer and 8" table saw, but it has too much power and
collapses the hose when I try to use it on my Millwaukee ROS, so I wound up having to keep my old small shop
vac for use with my sanders, sometimes you just cannot simplify life easily.
I found it best to use the HF DC when I use my ROS's. I put the hose on the bench in front of what ever I'm sanding. My shop is in the garage so I open both doors and put a fan blowing across my body which keeps the dust that the DC didn't get from going in my face. ROS's are just messy and you cant control it any more than you can control the jointer chips.
Dust collectors use fan type blowers to move large volumes of air with relatively low static pressure (suck power). The key to thier sucess is matching the piping system well to the blower. If you have small pipes, long pipes, lots of 90 deg bends or redcution couplers, the piping system can have too much resistance to flow and the DC blower won't move enough volume to be effective.
Shop Vacs are just the opposite. They generate large static pressures, but don't move large quantities of air. They are ideal for moving material though small pipes and will collect chips and debris. But they will not move enough volume of air to get the fine dust (with is the stuff that actually gets into your lungs and can cause health problems).
In your situation, I would suggest getting a big and powerful shop vac., a HEPA filter upgrade for it (with a spare) and either make a Thein style seperator or buy a Dust Deputy type set up. The cyclone will help greatly to prevent the chips and debris from clogging up your HEPA filter. This should help you get the lion's share of the visible debris.
Then I would put a ceiling mounted air filter in, to clean up the shop air of the fines.
You probably still want to ware a good quality dust mask when sanding, etc…
This is not an ideal setup, but is a huge improvement over nothing, or just a stock shop vac.
To take advantage of a larger DC, you really need to think "system" and size the pipes and hook ups to support that kind of air flow.
I agree with the other posts about using a shop vac if all your fittings are 2.5". Closing down a 4" hose to 2.5" doesn't work as well as a shop vac. It's not logical but it's true. And it's a lot less money and space to use the shop vac.
Don't get me wrong - I like big dust collectors. I have two of them for my equipment that uses big fittings. And I have a 4" hose that goes into a couple of 2.5" fittings but it doesn't work as well as a single shop vac would - It was convenient though since the DC is already setup. You can see some pics towards the bottom of the workshop thread. For your application, I would use the shop vac.
Since all your tools are setup for 2.5" ports I would start with a shopvac that is suited for those. should you ever upgrade to machines with 4" openings you can upgrade to a higher rate full DC - and still use the shopvac for the smaller tools, and/or cleaning up the shop (it won't be wasted or left unused)
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
