Is this normal for a Stanley no. 7?
« back to Hand Tools forum
Forum topic by JJohnston posted 07-20-2013 03:41 PM 1256 views 0 times favorited 15 replies Add to Favorites Watch
View JJohnston's profile
JJohnston
1622 posts in 3286 days
07-20-2013 03:41 PM
Here are some side-by-side shots of a Stanley no. 5 and a no. 7. When the iron is set to cutting depth, the depth adjustment on the 7 seems to be backed way out. Here’s the 7 – note how there’s no adjustment screw showing beyond the knob:
Here’s the 5 for comparison. Note there’s about 3/8” of screw showing:
Here’s a side shot of the 7. Note how much forward tilt there is to the depth adjustment fork:
Here’s the 5. Not as much forward tilt:
Here are the irons and chipbreakers side by side, 5 on the left, 7 on the right. The hole for the adjustment fork is farther back on the 7, which is actually reducing the problem. If it were farther forward, where it is on the 5, it would be even worse.
These are ebay planes, so they might well have been cobbled together from parts from different models and different eras.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
15 replies so far
View Don W's profile
Don W
18707 posts in 2562 days
#1 posted 07-20-2013 04:18 PM
I can’t tell by these pictures if all parts are correct, and note sometimes planes left the factory with parts from previous models. Stanley was noted for that.
the fact that the adjuster is at a different location could be from several factors including depth of cut, frog placement, iron sharpened angle, chip breaker adjustment, etc.
It looks like your #7 chip breaker is much closer to the end than the #5. Neither is right or wrong, just set for a different cut.
Along with the fact Stanley did change frig design and as far as I know, all chip breakers are the same.
Is it a problem other than its just different?
View planeBill's profile
planeBill
506 posts in 2404 days
#2 posted 07-20-2013 04:38 PM
I was thinking that the 7 iron looks like it has been ground more than the 5 iron so it is shorter so needing to be adjusted out more? Maybe? ??
-- I was born at a very young age, as I grew up, I got older.
View unbob's profile
unbob
810 posts in 1898 days
#3 posted 07-20-2013 05:33 PM
The cap iron “chip breaker” is way far back on the No7. That is what adjusts the blade.
That said, I have a few planes that the adjuster knob is at the end of travel with the blade retracted. seems to be no problem.
View WayneC's profile
WayneC
13754 posts in 4092 days
#4 posted 07-20-2013 05:39 PM
The real question is does it function correctly? :)
View Bill White's profile (online now)
Bill White
4929 posts in 3955 days
#5 posted 07-20-2013 05:41 PM
Iron on #7 is in need of replacement soon. Just a wear issue.
Bill
-- bill@magraphics.us
JJohnston
#6 posted 07-20-2013 05:59 PM
I haven’t used these yet. Just got them thru ebay, and haven’t even done the cleanup/sharpening yet.
If it just comes down to function, if there’s nothing obviously WRONG, I can live with it.
View Loren's profile
10377 posts in 3643 days
#7 posted 07-20-2013 06:02 PM
Fork pivot pins appear to be positioned differently in
the frog. For that matter, the frog castings look
different in other ways too.
JJohnston
#8 posted 07-20-2013 06:06 PM
Yes they do, now that you mention it.
View JustJoe's profile
JustJoe
1554 posts in 2033 days
#9 posted 07-20-2013 08:13 PM
+1 on the short iron. If you flip them over so the chipbreakers aren’t covering them, it would be interesting to see how much, if any, life is left in that #7 cutter.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View bandit571's profile
bandit571
19965 posts in 2678 days
#10 posted 07-20-2013 08:16 PM
Looks like the 7 is a newer model frog than the 5? One might be the 3rd version Stanley made, and the #7 is the 4th?
JJohnston
#11 posted 07-20-2013 09:04 PM
It’s possible. I don’t know the subtleties of the different eras/model numbers. The bed on the 7 is an older style, without the ribs along the toe and heel, and with the older style lever cap without the kidney shaped hole. The 5 seems newer all around, with the ribs, the kidney shaped lever cap hole, and the “Stanley” with the orange background on the lever cap. Here are the irons and chipbreakers apart. 5 on the left, 7 on the right.
Here they are, put together and turned over. Both chipbreakers are now about the same distance from the edges.
Don W
#12 posted 07-20-2013 09:15 PM
The ribs don’t indicate age for the most part. It just make it a #5C (corrugated) instead of a #5.
The length of the #7 iron is fine. You’ll have to do a lot of woodworking to use it up. The length of the iron also has nothing to do with the adjustment. The iron move independent of the chip breaker. The chip breaker moves the iron with the adjuster.
It doesn’t sound like you have a problem, just 2 different vintage planes.
JJohnston
#13 posted 07-20-2013 09:28 PM
These are the ribs (or lack of) that I was referring to. These are both smooth soles.
Don W
#14 posted 07-20-2013 09:31 PM
ahhh, sorry, miss understood. That does make the #5 newer.
JJohnston
#15 posted 07-20-2013 10:21 PM
No problem. Guess I’ve got some work to do before I can tell for sure.
