Best way to cut a 18" long bevel?
Forum topic by lateralus819 posted 07-20-2013 01:57 AM 2174 views 0 times favorited 16 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 2007 days
07-20-2013 01:57 AM
I’m going to be starting a TV stand hopefully soon, one aspect has me thinking.
I designed this, and i would like to add the top “shelf” above the drawers for misc items such as the tv receiver. Since my chop saw only does a max width of 14” and i don’t have access to a table saw at home (I have one i can use at work, but i DOUBT its accurate enough to do this)
How would you do it? Its 18” wide. I was thinking of ripping a board a little wider, with the appropriate angles, insetting some strong magnets and using it as a guide for a pull saw. Would this give me the accuracy i need?
16 replies so far
View JustJoe's profile
JustJoe
1554 posts in 2156 days
#1 posted 07-20-2013 02:07 AM
If the tablesaw at work has a tilting arbor, there is no reason it’s not accurate enough to cut a bevel.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
lateralus819
#2 posted 07-20-2013 02:12 AM
It does tilt, but cross cutting a piece 4’ long riding against the fence bearing on 18” of surface seems scary.
View tomd's profile
tomd
2165 posts in 3888 days
#3 posted 07-20-2013 02:21 AM
Use a miter gauge to guide the cut not the fence or use a cross cut sled if available.
-- Tom D
View jte9999's profile
jte9999
25 posts in 2220 days
#4 posted 07-20-2013 02:22 AM
A straight edge clamped to the piece guiding the sole plate on a circlular saw with the appropriate bevel set might work unless I’m not understanding what you are doing.
—jay KCMO
-- --half full, half empty? How about twice as big as it needs to be?
View Loren's profile
10477 posts in 3765 days
#5 posted 07-20-2013 02:23 AM
That’s a cut you can make if the fence is set up
parallel. However, if the work isn’t bearing flat
against the table, there will be variations in the
bevel. This is a tricky cut if you need precision.
One good way to do it is with a router. Rough
cut the board 1/8” overlong and fasten a template
to the bottom. You can make a template for the
whole shape if you like. Rout it square with a
flush trim bit, then rout the bevel with a 45
degree bit with a bearing.
As an aside, the way to cut a long end bevel most
accurately on the table saw is with the work
held sticking up in the air, attached to a jig
riding on the fence. Some box makers who
cut mitered corners make special jigs that
allow the blade to be left at 90 degrees and
cut the miters to match perfectly with the jig.
18854 posts in 1974 days
#6 posted 07-20-2013 02:26 AM
I may not be picturing exactly what you’re doing, but my thoughts are router or using the chopsaw and doing it in two cuts, one from each side assuming that the saw will tilt the direction needed once the piece is turned around.
#7 posted 07-20-2013 02:38 AM
If you’ll be using plywood, the ends may be cut square and
edgebanded with 1/4” thick solid wood. The appearance
from the end of the case will not be ugly.
Then, the front board can be edgebanded too, but mitered
so it looks from the front like a fancy mitered case.
View AlaskaGuy's profile
AlaskaGuy
4361 posts in 2427 days
#8 posted 07-20-2013 03:41 AM
Never mind.
lateralus819
#9 posted 07-20-2013 12:41 PM
Heres a closer pic, where a and b meet at a 40 degree angle it looks like on the protracter.
View Derek Cohen's profile
Derek Cohen
391 posts in 4086 days
#10 posted 07-20-2013 03:36 PM
Since only the front edge will show, just apply a bevelled edge to whatever method of jointing you wish.
Regards from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
View gfadvm's profile
gfadvm
14940 posts in 2808 days
#11 posted 07-21-2013 12:42 AM
This appears to be a crosscut bevel and not a rip. So you should be able to tilt your tablesaw blade to the appropriate angle and do this with a sled or extended fence on your miter gauge.
lateralus819
#12 posted 07-21-2013 01:15 AM
Maybe i can clamp a 2×4 to the miter gauge for added support.
gfadvm
#13 posted 07-21-2013 02:03 AM
Most miter gauges have a couple of holes so you can screw an auxillary fence to them. Just make sure the board used for the aux fence is straight and flat.
View cutmantom's profile
cutmantom
407 posts in 3152 days
#14 posted 07-21-2013 02:09 AM
at 18 inches wide is this plywood or a glueup, if plywood just butt joint it then miter the edging
View lumberjoe's profile
lumberjoe
2899 posts in 2366 days
#15 posted 07-21-2013 02:16 AM
This
you have a few options:
1- Leave a lip at the bottom of the bevel to ride the bearing on (which would look really nice I think)
2 – attach fence at the end of the bevel to ride the bearing on
3 – Set your router table fence correctly and don’t worry about the bearing
