| Forum topic by birdman | posted 394 days ago | 585 views | 0 times favorited | 6 replies | ![]() |
394 days ago |
Hi All, I have a drawer lock bit that I would like to use to make boxes, instead of drawers. It’s a Rockler with a 1/2” cutting surface. what I have read so far sayss the front and back (for a drawer) should be 3/4” thick while the sides can be 1/2”. Why this restriction on the stock thickness? Seems to me 1/2” would be good all around, as with a box. Any one know if this is right? -- DavidP - still count on my fingers and toes - not for math, just inventory! |
394 days ago |
I make drawers on a regular basis and make just as many with the drawer lock bit as I do with thru dovetails. All are constructed from 1/2” thick baltic birch plywood for front, back, sides and bottom. Don’t fall prey to everything you hear. Ed -- Come on in, the beer is cold and the wood is dry. www.crookedlittletree.com |
394 days ago |
My kitchen cabinets that I’m making now are made with the drawer lock bit and all with 1/2” baltic birch for the drawers. sides and bottom. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
394 days ago |
thanks, guys – ‘just got back. What height do you set the bit at? -- DavidP - still count on my fingers and toes - not for math, just inventory! |
393 days ago |
The suggestion probably has to do with “load”. The way a drawer is stressed in use. The sides just carry the ends, and as their bit is designed it probably leaves too little material left in the ends to resist tear out should the drawer hang up in some part of its’ travel. Could work o.k. as a box bit as the stresses are placed differently but I’d be a little worried that it might get a little skinny in places. Common sense should prevail in this situation. In really skinny box situations modifying your method completely and using a spiral upcut bit bit will give better results as it pulls material from the wider “face” of the wood rather than pushing it out of the narrow end like a saw blade or box bit will do. (At least it does it on a far smaller scale) This is another set of problems (completely unrelated to those mentioned in the previous paragraph) that come into play when the sides of the box get small. Just to put a number on it I’d say 3/8” but again it will be greatly affected by the material being used and there is no substitution for experience. Cut a couple of sides long and create a joint, then stress it to the point of breaking. Do the same with the other two sides but with a different joint. Note the difference and choose accordingly. I use the pigs/pillows analogy. Will this box be used to ship pigs or pillows? Your choice of joint should reflect the contents/intended use. Hope this helps. |
393 days ago |
As GC points out, could it be that the bit in question can’t properly cut the profile in 1/2” stock? Drawer lock bits usually create an “A” and “B” profile, which interlock. I’m not personally familiar with the Rockler version, but one of the profiles many not leave enough meat in 1/2” stock to endure as the front and back. -- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread... |
393 days ago |
I never thought about a “drawer lock bit” I have been making a few draws and have been cutting them on the table saw or using dove tails. I’ll have to buy the bit and give it a try. What a great idea.. what woudl I do with out lumber jocks, probably waste a lot more time and wood. -- "so much to learn and so little time".. |
| Forum | Topics |
Woodworking Skill Share
2936 |
3966 |
259 |
956 |
226 |
Woodworking Trade & Swap
624 |
Coffee Lounge
2403 |
LumberJocks.com Site Feedback
525 |
