Dust Collection - Static Shock - Novice Question
Forum topic by James posted 07-18-2013 08:51 PM 1026 views 0 times favorited 9 replies Add to Favorites Watch
View James's profile
James
103 posts in 1657 days
07-18-2013 08:51 PM
Can somebody experienced explain the concerns of fire hazard with dust collection? I’ve seen it mentioned a few times and I haven’t set up my system yet. I use it mainly for cleanup. My shop is expeditionary by nature. When I get out of the Marine Corps next year, we’ll move to Anchorage where the house I buy will have a dedicated woodworking space. Then, I’ll spend money on hard lines and whatnot. Gimme some pointers if you would.
Currently, I have a squirrel cage fan with a dust rite bag on it and a stand-alone shop vac. I’m not opposed to spending money on a different system or different components once I move and have a permanent shop.
-- James - Semper Fi
9 replies so far
View PurpLev's profile
PurpLev
8534 posts in 3519 days
#1 posted 07-18-2013 08:53 PM
don’t worry about it… the amount of static electricity required for anything of that sort is not something to be found in the home shop.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 1943 days
#2 posted 07-18-2013 08:58 PM
You can search the many threads on this topic for solutions if you want them… However I am +1 PurpLev on this. It is not dangerous until you reach the industrial scale, and even then we are talking big industrial… Just annoying. I found it annoying enough that I switched to 4” hose with integrated grounding wire, and ground my connections… That just doesn’t seem like it is gonna fit your econo modular shop right now.
-- Who is John Galt?
James
#3 posted 07-18-2013 09:14 PM
Grounding your hoses?
joeyinsouthaustin
#4 posted 07-18-2013 09:17 PM
Yes.. The Hoses I buy are spun with a metal wire down them. Where the connections are made the wire is grounded to the machine, and dust collector, and across any of the plastic joints. This works ok in permanent set ups, but is a pain if you are moving hoses around all the time.
View Sandra's profile
Sandra
7176 posts in 1945 days
#5 posted 07-18-2013 09:18 PM
Not to get laughed off the block, but with my portable system, the static makes the dust cling to the outside of my Dust Deputy. No fire hazard, but I keep a few dryer sheets on my shopvac cart and give everything a rub down occasionally. I also keep a dryer sheet between the two buckets. Works for me.
I’ve also done this at work with equipment that was sensitive to static.
-- No, I don't want to buy the pink hammer.
joeyinsouthaustin
#6 posted 07-18-2013 09:19 PM
Sandra I have heard of that one.. question is always floral, or summer rain? :)
View crank49's profile
crank49
4028 posts in 2841 days
#7 posted 07-18-2013 10:08 PM
The smallest dust collector I ever blew up was a 5000cfm unit in a foundry pattern shop.
Can they blow? Yes!
In a small home shop?
Not likely.
View TheDane's profile
TheDane
5348 posts in 3533 days
#8 posted 07-18-2013 10:16 PM
Fire danger is pretty low … never heard of a home shop fire caused by not grounding the DC.
There is, however, a danger of static discharge damaging electronics (computer, digital instruments, etc.) in the shop.
Sandra
#9 posted 07-18-2013 10:24 PM
joey – I prefer the Costco Chemist bouquet.
