Suggestions on finishes for a couple of different wood doors.
Forum topic by Randy_ATX posted 07-18-2013 05:37 PM 970 views 0 times favorited 4 replies Add to Favorites Watch
View Randy_ATX's profile
Randy_ATX
878 posts in 2409 days
07-18-2013 05:37 PM
I will be finishing a couple unfinished doors for a “cabin” home my mom has. There are two different doors.
One is an exterior door with a type of mahogany veneer on it. The second door is an interior knotty-alder. In both cases it has been requested to keep the finish as clear as possible (no amber tint or yellowing after a while).
I don’t have the capability of spaying, so this will be a brush application. I would be interested in what others with more experience would choose to do.
Thank you!
-- Randy -- Austin, TX by way of Northwest (Woodville), OH
View Jim Jakosh's profile
Jim Jakosh
20305 posts in 3072 days
#1 posted 07-18-2013 08:48 PM
Polyurethane is a good finish for doors where there will be a lot of handling and wear on the finish. There is also an exterior one that gives UV protection but you could just buy that one and use it on both. There is a wipe on poly too but you can wipe on the regular poly with an old T-shirt. For doors, I like to use a wide foam brush and I always put a little naphtha in the poly first. I pour some poly out in a yogurt cup and add a table spoon of Naphtha to that small quantity, stir it in and then apply it. The naphtha makes it level out faster and dry quicker so less dust can settle in it. Let it dry overnight and then light sand with 400 wet paper and water. Wipe it dry and apply subsequent coats until you like what you see!!
When I moved to Michigan in 1980 I took 30 doors out of the house stripped them all, stained them and put poly on them and they still look good today!
.................Jim
View Clint Searl's profile
Clint Searl
1533 posts in 2328 days
#2 posted 07-18-2013 11:52 PM
Boat deck finish for the exterior, and waterborne poly for the interior.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3125 days
#3 posted 07-19-2013 12:12 AM
+10 Clint.
-- jay, www.allaboutastro.com
Randy_ATX
#4 posted 07-19-2013 02:50 AM
Jim, Clint, and Jay – Thank you for your suggestions! Wow Jim, 30 doors is quite an undertaking. I appreciate the details you provided.
