Show us your homemade tools.
« back to Hand Tools forum
Forum topic by Klickitat posted 07-18-2013 03:40 PM 3021 views 1 time favorited 15 replies Add to Favorites Watch
View Klickitat's profile
Klickitat
51 posts in 1894 days
07-18-2013 03:40 PM
I have been drooling on router planes for a while now and last night I came across a video on Youtube of a guy who built his own router plane. Now I do not know why I have not thought of it before as it is as simple as it gets. I know people build smoothing planes all the time. There has got to be a lot of hand tools that people build every day.
What is more beautiful than a handmade tool that you built to use to build beautiful things?
Show us your handmade tools.
15 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3737 days
#1 posted 08-29-2013 03:26 AM
An interesting topic I am surprised there have been no responses.
I’ve only made a couple of tools, a mallet my children and I is posted in my projects.
View knockknock's profile
knockknock
447 posts in 2197 days
#2 posted 08-29-2013 01:10 PM
My (not so beautiful) home made panel gauge (uses my awl as the pin):
View Don W's profile
Don W
18754 posts in 2592 days
#3 posted 08-29-2013 01:32 PM
Click for details
Click for details
Click for details
Click for details
Click for details
Some more if your interested.
View fatandy2003's profile
fatandy2003
262 posts in 2268 days
#4 posted 11-07-2015 01:35 PM
JordanP and I swapped homemade panel gauges. Here is the one I made for the swap.
Click for details
-- -- Andy, “Those who expect to reap the blessings of liberty must undergo the fatigues of supporting it” - Thomas Paine
View jeffswildwood's profile
jeffswildwood
3232 posts in 2001 days
#5 posted 11-07-2015 02:07 PM
Don and Andy, how did you post these project cards.
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
View HerbC's profile
HerbC
1763 posts in 2883 days
#6 posted 11-07-2015 02:55 PM
- jeffswildwood
On any Project Page, upper lefthand side has section with code for imbedding this project. Just copy the code and insert into any post…
Hope that helps.
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View lndfilwiz's profile
lndfilwiz
106 posts in 1624 days
#7 posted 11-07-2015 02:58 PM
Use for an old grill. Makes the cutoff saw easy to move around.
-- Smile, it makes people wander what you are up to.
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1248 posts in 1737 days
#8 posted 11-07-2015 03:02 PM
Click for details
Click for details
Click for details
For searching LJ use the tags. Here with “router plane”: http://lumberjocks.com/projects/tag/router+plane
-- "Do or Do not. There is no try." - Yoda
View Tedstor's profile
Tedstor
1643 posts in 2657 days
#9 posted 11-07-2015 03:27 PM
- lndfilwiz
You should have made a toolbox out of the fire box. :)
View Ripthorn's profile
Ripthorn
1458 posts in 3009 days
#10 posted 11-07-2015 03:32 PM
Just a few that I have pictures/projects of:
Click for details
Click for details
Click for details
Click for details
Click for details
View Kelly's profile
Kelly
2039 posts in 2968 days
#11 posted 11-07-2015 05:29 PM
These are just gauges for doing measurements, like the inside of cabinets, for laying laminate in them, for example, if you wanted to add shelves that fit exactly between two walls.
View bandit571's profile
bandit571
20220 posts in 2707 days
#12 posted 11-07-2015 05:54 PM
Old lathe chisel and a block or two of oak..
Chinese style skewed rebate plane
Has a fence on the bottom to set the width of the cut…
View DrTebi's profile
DrTebi
267 posts in 3291 days
#13 posted 11-07-2015 06:15 PM
I made my own awl last year some time. The metal rod was made “pointy” and tempered, the ebony handle turned, and the ferule is from a copper pipe. Everything was one on the Shopsmith:
jeffswildwood
#14 posted 11-08-2015 02:04 AM
Click for details
View bondogaposis's profile
bondogaposis
4763 posts in 2375 days
#15 posted 11-08-2015 05:35 AM
Just your typical stuff; mallets, screw drivers, marking knife, awls and a thin blade parting tool.
-- Bondo Gaposis
