| Forum topic by robdew | posted 390 days ago | 217 views | 0 times favorited | 10 replies | ![]() |
390 days ago |
My edge jointer cuts the front of a work piece more that the back. That is, if I feed the piece through several times there is a noticeable taper created that begins thinner at the front and ends thicker at the back. It’s actually an ancient Delta/Milw model that’s on the old ww machines website, so it needs a little TLC every once in a while. I am wondering if this is a setup problem or a technique problem. |
390 days ago |
Rob, -- I love the smell of sawdust in the morning.... |
390 days ago |
I am mostly self taught from watching Norm and Marc. I believe I am correctly placing pressure evening toward the fence and table. |
390 days ago |
sounds like the opposite of Spaids problem. Just like him, I’d start by checking the height of your outfeed table to be sure it is level with the top of the blade’s rotation. |
390 days ago |
Indulge the noob in me—wouldn’t an outfeed table lower or higher that the top of the blades result in a more or less aggressive cut along the whole length of the board? |
390 days ago |
Both your infeed table and outfeed tables need to be in the same plane. Use a good quality straight edge to check this adjustment. If they are not in the same plane, I would think that is causing the taper. Search the internet for a tune-up procedure. -- Nicky |
390 days ago |
Setup…Check your in feed and out feed tables. Out feed table needs to be exact height as your blades. |
390 days ago |
What Dennis said. It sound like your outfeed is higher than the blades, which will lift the board away from the blades as you apply pressure, so the last part of the board going across won’t even be cut. -- Tim -- http://tmuli.com |
390 days ago |
I had that same problem with my brand new Grizzly jointer. I called their technical department, and they had me stretch a straight edge across the length of the infeed/outfeed tables, and measure the gap at the ends. Then he instructed me to shim the ways on opposite side that was low, bringing it up on the low side. It worked!! I attributed it being off due to me and a co-worker lifting it on to it’s base by the tables. It’s perfect now!! -- Matt, Houston Texas |
390 days ago |
I vote with the guys who suspect that the infeed and outfeed tables are not parallel. You will need to obtain a very accurate, and long, straight edge. I recently purchased the 50” Veritas aluminum straightedge from Highland Woodworking and it has been very useful in machine set-ups. -- "Heaven is North of the Bridge" |
387 days ago |
here is little video i did…might help…i agree you have to be adjusted correctly or you will experience what you are describing http://www.youtube.com/watch?v=UqVkISnNx0w |
| Forum | Topics |
Woodworking Skill Share
2912 |
3939 |
256 |
948 |
223 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2383 |
LumberJocks.com Site Feedback
523 |
