Finishing for CA softwoods in a small apartment
Forum topic by siavosh posted 07-18-2013 03:06 AM 940 views 0 times favorited 8 replies Add to Favorites Watch
View siavosh's profile
siavosh
674 posts in 2112 days
07-18-2013 03:06 AM
Topic tags/keywords: finish pine softwood apartment
Hi folks,
Complete novice here. I just started making small projects out of low cost pine and redwood and am overwhelmed with the information online. I’m sure this has been asked before, but I have an additional constraint where I don’t have a dedicated workshop or garage and am concerned about fumes, toxicity, ventilation etc.
I was wondering if you all have recommendations for a simple, easy, non-toxic, apartment friendly finish for small pine/softwood projects. I’d like to preserve and enhance the look/grain of the wood so I’m guessing I prefer a clear finish.
Thanks!
-- http://woodspotting.com/ -- Discover the most interesting woodworking blogs from around the world
8 replies so far
View shampeon's profile (online now)
shampeon
1899 posts in 2425 days
#1 posted 07-18-2013 03:18 AM
Shellac. The solvent is alcohol, and that will cause some fumes, but shellac dries very quickly, and doesn’t out-gas. It’s non-toxic (it’s used to coat pills and apples), and it looks great on pine. You can wipe it on. Pick up some premixed Bullseye Seal Coat shellac from the hardware store and a can of denatured alcohol.
View Manitario's profile
Manitario
2705 posts in 3124 days
#2 posted 07-18-2013 03:31 AM
some of the water based finishes have less potent odor than the typical solvent based finishes, and they clean up with soap and water. It’s hard to mess up finishing pine! Pick up a few small cans of finish and try on some scrap.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3400 days
#3 posted 07-18-2013 04:28 AM
Ditto, shellac.
-- jay, www.allaboutastro.com
siavosh
#4 posted 07-18-2013 07:44 AM
Thanks folks, shellac it is!
View Clint Searl's profile
Clint Searl
1533 posts in 2602 days
#5 posted 07-18-2013 11:51 AM
Waterborne poly: no volatiles, non-toxic, no odor, fast dry, durable, soap and water cleanup.
Shellac: alcohol based, toxic, odiferous, poor protection, messy alcohol cleanup.
siavosh
#6 posted 07-18-2013 04:50 PM
Thanks Clint, maybe I’ll get both and experiment…
shampeon
#7 posted 07-18-2013 07:02 PM
Shellac is non-toxic. Citation. Denatured alcohol is, but it is the solvent and will evaporate quickly (most of it within 20 minutes).
Polyurethane is similarly non-toxic when cured. Waterborne poly has much fewer VOCs than oil-based poly, but still outgasses. E.g. see the summary here. I’ve never used a waterborne finish that didn’t have odor.
Both would work. Shellac will cure faster, which means less time with the windows open, but Clint is right that cleanup is easier with waterborne finishes.
View crank49's profile
crank49
4032 posts in 3212 days
#8 posted 07-18-2013 08:34 PM
Minwax Polycrylic. A clear water based durable finish. Drys super fast, no smell. Not cheap, however.
Shellac is good also, but dissolves in the presence of alcohol so don’t use it on the bar. A super sealer to put under other finishes.
