Jet 1000B Air Filter wobble?
Forum topic by Vududude posted 07-18-2013 02:19 AM 1202 views 0 times favorited 6 replies Add to Favorites Watch
View Vududude's profile
Vududude
41 posts in 1760 days
07-18-2013 02:19 AM
I bought a used Jet 1000B air filter. I ended up just putting i up on a hanging shelf I have in my garage. The issue now is that there is a very slight wobble to the fan blades, and it does introduce some vibration that becomes more pronounced at the higher speeds.
Any ideas on what the most likely causes are? And anyone out there actually taken the air duct and fans down from the assembly to fix it?
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3681 days
#1 posted 08-29-2013 03:24 AM
Is there a build up of dust on the blades?
Vududude
#2 posted 08-29-2013 03:48 PM
Nope, no buildup of dust. Overall it seems to work well except for the wobble. I’ve read a lot of posts online about the wobble, I did find one post on a forum where the guy took it apart and straightened out the assembly which was slightly off level which fixed it. I’ve just been too lazy/apprehensive about doing the same.
Mark Shymanski
#3 posted 08-30-2013 06:13 AM
Yeah you always have to be careful that you don’t have any ‘spare’ parts once you reassemble a ‘fixed’ tool:-)
View Lynden's profile
Lynden
74 posts in 3115 days
#4 posted 08-31-2013 01:50 AM
I bought my 1000B new and it had a bad vibration the first time I turned it on. I took it apart and found the motor support brackets were slightly bent and the fan was out of balance. I was able to straighten the support brackets and Jet sent me a new fan. Works fine now. Due to the weight of the motor and the inadequate styrofoam blocking around the motor, the support brackets on the 1000B are easily bent if the unit is dropped. Mine had a dent in one of the corners of the case, so it was definitely dropped. Did you read the Amazon reviews? Others have had this same problem.
http://www.amazon.com/708620B-AFS-1000B-Filtration-Electrostatic-Pre-Filter/product-reviews/B00004R9LO/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
Vududude
#5 posted 08-31-2013 03:49 PM
Yeah I definitely noticed the reviews. I bought mine used and when I listened to it before buying I didn’t notice the wobble or hear any vibration. not sure if anything got bent while transporting it home. it works fine at low settings, but I’ll probably take it apart at some point in the future.
anything important I should know about before trying to take it apart? or advice on straightening it out?
View kizerpea's profile
kizerpea
774 posts in 2335 days
#6 posted 09-01-2013 01:16 PM
The blade could be bent or out of balance. post a pic of the blade.
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
