Loose tenon thickness -- your 2 cents
« back to Joinery forum
Forum topic by Furnitude posted 07-17-2013 08:11 PM 1180 views 0 times favorited 6 replies Add to Favorites Watch
View Furnitude's profile
Furnitude
380 posts in 3383 days
07-17-2013 08:11 PM
I’m making a table out of walnut (but oak and cherry in the future) that will have 1/2” thick stretchers and I’m going to use loose tenons. (they will extend about 5/8” into the legs and the stretchers.) I’m thinking of making the tenons 3/16” thick, going with the 1/3 thickness rule. There will be double tenons, but i’m worried that 1) the tenons will be so thin that they could break if there’s any wracking force and 2) the tenons, if I made them any thicker (say, 1/4” thick), would blow out the sides of the stretcher with wracking. To complicate matters, the stretchers will be at about a 45 degree angle to the legs. The below drawing is just a sketch and isn’t proportional…
I’m afraid I’m thinking this to death and should probably just make them. But I’d appreciate any wisdom…
Thanks,
Mitch
-- Mitch, http://furnitude.blogspot.com Also blog at http://www.craftsy.com/blog/author/mitch-roberson/
CanadianWoodChuck
402 posts in 3790 days
#1 posted 07-17-2013 08:58 PM
In my humble opinion …. I believe that any loose tenon that is a nice tight fit becomes part of the wood and so any structure that you loose making the mortise you replace with the tenon. I don’t think this is an issue. Bruce
-- Wood Chuck (Bruce) http://3dwoodworkingplans.com
View BTimmons's profile
BTimmons
2303 posts in 2361 days
#2 posted 07-17-2013 09:03 PM
Being on the inexperienced side myself, if faced with the same problem, I would probably build a mockup of that joint and subject it to stress testing.
-- Brian Timmons - http://www.BigTWoodworks.com
View Fuzzy's profile
Fuzzy
297 posts in 3865 days
#3 posted 07-19-2013 02:03 PM
Possibly drill a 3/8” hole right between the tenons … counterbore it to accommodate a properly sized screw … assemble the joint using both the tenons and said screw … cut a face grain plug to fill the hole … trim flush ???
The plug will be in a low visibility area, and, if done correctly would be totally invisible.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
View HorizontalMike's profile
HorizontalMike
7736 posts in 2790 days
#4 posted 07-19-2013 02:27 PM
I love loose tenons and even made a router based horizontal mortising machine to make most of my joinery. That said, from your drawing, I would recommend a spline type tongue and groove. On the style, cut a 90-degree mortise, and on the diagonal I would a full spline at the desired angle.
A chisel can square off the bottom AND top of the spline to make it square with the mortise hole, top and bottom. I think that that would be easier than the floating tenon since you may not have a horizontal mortising machine like mine. I can actually set the bed/piece at 45-degrees and pull this off pretty easily, but not so much with a more traditional mortiser.
Just my 2-cents…
View waho6o9's profile
waho6o9
8071 posts in 2453 days
#5 posted 07-19-2013 02:52 PM
Titebond lll glue and you’re good to go Mitch.
404 - Not Found
2544 posts in 2846 days
#6 posted 07-19-2013 04:52 PM
I would do it like this with a loose tenon
It’s easy to make a table to hold a router horizontally, it doesn’t need to have all the bells and whistles (though that would be nice)
