Distressed Saw Kerf
Forum topic by kzot posted 07-17-2013 04:55 PM 3274 views 0 times favorited 15 replies Add to Favorites Watch
View kzot's profile
kzot
10 posts in 3148 days
07-17-2013 04:55 PM
Topic tags/keywords: distressed saw kerf rustic
I’m trying to mill some old wood to have the rough kerf marks on some of the surfaces but I can’t seem to find a way to make my ‘clean cut’ saw kerf look distressed after cutting.
I’m not sure if it requires a special blade, modification of an old blade or some other technique but I know for sure that this is the place for an answer.
Thanks ahead of time…hoping you can help :^)
-- Kzot
15 replies so far
View 69BBNova's profile
69BBNova
341 posts in 2179 days
#1 posted 07-17-2013 05:04 PM
I’m only guessing here but I think you could use an old (no carbide) blade and make the set on the teeth random…
Although I’m not sure how far out you could go, but who knows it may actually work.
View Clint Searl's profile
Clint Searl
1533 posts in 2324 days
#2 posted 07-17-2013 05:44 PM
Those marks come from a 36 inch sawmill blade.
17929 posts in 1819 days
#3 posted 07-17-2013 06:03 PM
Also, doesn’t it leave those marks due to the speed at which the wood if fed past the blade. Not sure you want to try something where you are pushing the wood that fast. That seems dangerous.
View Grandpa's profile
Grandpa
3259 posts in 2638 days
#4 posted 07-17-2013 06:12 PM
experiment with a rip blade non-carbide type. The fewer teeth the better. If that doesn’t work try putting more set on the blade with a pair of Vise Grips. You should be able to reproduce what you are looking for.
View Randy_ATX's profile
Randy_ATX
878 posts in 2405 days
#5 posted 07-17-2013 06:22 PM
I’ve have some lumber from a long time ago that was cut with the type of sawmill Clint mentioned. It is the last photo in this project of mine: http://lumberjocks.com/projects/76052 To try and recreate this look would be difficult without a huge old-school mill.
-- Randy -- Austin, TX by way of Northwest (Woodville), OH
Grandpa
#6 posted 07-17-2013 06:30 PM
you can’t make the long cuts because the blade is not that large but you can make those with the 5” radius from a regular table saw. I have made these at times not intending to do it and I think you could make a distressed look with a little experimentation. I would get an old blade and experiment. Nothing ventured nothing gained.
View bondogaposis's profile
bondogaposis
4680 posts in 2314 days
#7 posted 07-17-2013 06:37 PM
Some of it has to do with MC, sawmills generally saw green logs and that increases the tendency for those tearing tooth tracks seen on rough milled lumber.
-- Bondo Gaposis
Randy_ATX
#8 posted 07-17-2013 06:58 PM
Good point Bondo.
View WDHLT15's profile
WDHLT15
1729 posts in 2439 days
#9 posted 07-18-2013 02:56 AM
A tooth a little out of set causes those marks.
View Straightbowed's profile
Straightbowed
717 posts in 2261 days
#10 posted 07-18-2013 03:31 AM
chainsaw will do a good job of ditressing the wood
-- Stevo, work in tha city woodshop in the country
Straightbowed
#11 posted 07-18-2013 03:34 AM
if your cutting some thick stock just take a 8×8 lay on a flat then take a good flat board and lay beside 8×8 and turn saw on side kinda like chainsaw lumber mill and start sawing it will distress the hell out of it
Straightbowed
#12 posted 07-18-2013 03:36 AM
you might could just take a board and lay it down set it up a little higher than blade and run the saw down it like your trying to take a 1/8 or 3/16 off
View exelectrician's profile
exelectrician
2327 posts in 2390 days
#13 posted 07-18-2013 05:47 AM
Make the cut with a bandsaw
-- Love thy neighbour as thyself
Randy_ATX
#14 posted 07-18-2013 01:45 PM
James101 – I really l like your suggestion and solution – ingenious. ...and the fact you took time (I think) to sketch this up for the original poster. Well done.
View kzot's profile
kzot
#15 posted 07-19-2013 10:19 AM
Thanks to all. I have a better handle on how to replicate the old saw kerfs.
-- Kzot
