Any way to fix this mess?
Forum topic by noone posted 07-17-2013 12:34 AM 1458 views 0 times favorited 13 replies Add to Favorites Watch
View noone's profile
noone
583 posts in 2178 days
07-17-2013 12:34 AM
I think i’m totally screwed here.
I put one coat of Enduro Var, let it dry, sanded it back with 320, and then sprayed a coat of tinted EV with Transtint cordovan hoping I could just spray on the color nice and even. This is what I have now. It looks terribly lighter in the corners and edges where the toned finish has run off. It’s all running off the sides. And it looks so dark that it just might as well be paint. Do you know what I can/should do now? I’m asking the wife if we can just paint them at this point….. I’m looking for any options at this point. I’m so frustrated right now…....
13 replies so far
View Straightbowed's profile
Straightbowed
717 posts in 2204 days
#1 posted 07-17-2013 12:39 AM
actually I like it myself put some topcoat on a let it go
-- Stevo, work in tha city woodshop in the country
View Buckethead's profile
Buckethead
3194 posts in 1775 days
#2 posted 07-17-2013 12:43 AM
Those look great! Maybe it’s the low res here at LJ that’s hiding something we can’t detect, but from where I sit its a fantastic finish. Roll with it! Act like you meant to do just this, and all your neighbors will be asking for the secret.
-- Support woodworking hand models. Buy me a sawstop.
noone
#3 posted 07-17-2013 01:09 AM
Its actually not good at all. I’m trying to figure out how to get some tinted finish into the cracks. I guess i need to spray again and see what happens.
View ART LACKEY's profile
ART LACKEY
112 posts in 3285 days
#4 posted 07-17-2013 01:22 AM
Well, what are you trying to achieve? what color is it supposed to be? If you want it lighter your just going to have to strip it and start over.
-- Old turners don't die, they just turn to dust!
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3064 days
#5 posted 07-17-2013 01:39 AM
Use a glaze in the cracks…I like pitch black GF water-based glaze.
-- jay, www.allaboutastro.com
Cosmicsniper
#6 posted 07-17-2013 01:46 AM
And, BTW, a little Transtint goes a long way. You want to be able to sneak up on the result with 5 to 10 light passes. If you got it dark in less, then use less dye…and do a test board next time. :)
noone
#7 posted 07-17-2013 02:17 AM
Thanks for the replies.
I did use a test board. The test board was flat. This was not!
Tomorrow, i’m going to try to brush some of the tinted finish on the rounded edges and in the cracks and see what happens. Or spray it on, knowing i’m going to darken the rest of the surfaces too much.
My main mistake was that I flooded the surface trying to get the finish to stay on the rounded edges and into the cracks. I think I should have just let it go and then came back to the edges later…..
If I did want to strip this down, how do I strip wood? I’ve never done that before.
View AandCstyle's profile
AandCstyle
2978 posts in 2163 days
#8 posted 07-17-2013 11:54 PM
Could you apply some of the finish into the corners with a Q-tip or something like that?
-- Art
noone
#9 posted 07-18-2013 03:33 AM
This evening I brushed on several coats of tinted finish on the light profiled areas. It’s looking better. After several more coats to the light profiled areas by brush, I will sand the flat areas smooth and then give it one more coat of shader before I add clear finish. It looks like I can salvage this even though the end product is taking me 3 to 4 times longer to achieve.
View Finisherman's profile
Finisherman
227 posts in 1755 days
#10 posted 07-18-2013 04:11 AM
If you must strip the wood, use a methylene chloride stripper. The label will tell you whether or not methylene chloride is part of the formula. Brush the stripper on generously and then allow plenty of time for it to do its job. When the finish is completely softened, use a plastic scraper to remove the sludge. Be aware that you may need more than one coat of stripper to complete the job. When the wood is clean, use an abrasive pad or steel wool in conjunction with lacquer thinner, acetone or denatured alcohol to remove the stripper residue. From there you can sand, stain and refinish.
All the best
noone
#11 posted 07-18-2013 02:26 PM
Thanks for the stripping tips.
What brand of stripper do you use from the home centers?
How does one deal with the small cracks and crevices on profiled edges?
View waho6o9's profile
waho6o9
8099 posts in 2483 days
#12 posted 07-18-2013 02:40 PM
Live with it, they look great.
Maybe ask your friends and family for a second and third opinion?
Finisherman
#13 posted 07-18-2013 04:49 PM
I’m Canadian, so the consumer brand that I’m most familiar with is called Circa 1850. If you live in the states, I’d try one of the Klean Strip or Jasco removers. I’ve heard that Klean Strip is available at Lowes and Home Depot.
