Bench Dog Problems.
Forum topic by Elvispat posted 07-16-2013 01:59 AM 1744 views 0 times favorited 17 replies Add to Favorites Watch
View Elvispat's profile
Elvispat
6 posts in 1742 days
07-16-2013 01:59 AM
Topic tags/keywords: bench dog roubo question
This is my first time use this system. I have a question that I hope someone can answer. I have recently have completed a work bench. Roubo style. During the build I was using the bench dog hole with great success. Not that I have finished the bench and have put a finish on it and trying to keep the finish from entering the 3/4” dog holes, my iron bench dog will not hold. I’ve tried sanding the hole with no success. Do anyone have any ideals how to fix this problem?
Thanks in advance,
John
-- John, Tennessee
17 replies so far
View redSLED's profile
redSLED
790 posts in 1858 days
#1 posted 07-16-2013 02:28 AM
Your iron bench dog will not hold – how? Does it slip out, doesn’t go in or is it looser or does it get stuck?
View crank49's profile
crank49
4030 posts in 2937 days
#2 posted 07-16-2013 02:56 AM
What changed between “used DURING the build with great success” and “now it won’t hold”.
Is the top thicker now? The hole bigger? something get spilled in the hole?
And what kind of dog you talking about. Is it a bench “Dog” or a “Holdfast”?
If it’s a Holdfast, is it cast iron or wrought iron?
Elvispat
#3 posted 07-16-2013 09:06 AM
My bad. It’s a holdfast and not a bench dog. Sorry about that. The bench top is 4” thick and the hole is 3/4” diameter. The holdfast stopped holding after I applied the finish (equal parts boiled linseed oil, varnis, paint thinner). I tried to make sure I didn’t get any in the holes but I believe I soaked in on the edges. I’ve tried sanding the hole and no change. Is there some type of solvent I can use that will fix this that will not harm the bench? The bench top is Red Oak.
-- John, Tennessee
View theoldfart's profile
theoldfart
9615 posts in 2417 days
#4 posted 07-16-2013 11:41 AM
Try roughing up the shaft of the holdfast. Also I think many holdfasts don’t like a 4” top. May possibly need to counterbore from underneath! Check with Gramercy or any other company that makes them. God luck
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
View bondogaposis's profile
bondogaposis
4683 posts in 2317 days
#5 posted 07-16-2013 11:57 AM
Sand the shaft of the holdfast w/ 100 grit at right angles to length of it. It is amazing what a difference that makes.
-- Bondo Gaposis
Elvispat
#6 posted 07-16-2013 12:37 PM
4” thick top was no problem prior to the finish being added. I did sand the iron with 100 grit with no satisfaction. But didn’t sand at a 45 degree angle. I’ll try that and let you know. Also I did sand the holes with 80 grit sand paper with no change. Thanks for all the info and I’ll let you all know the outcome. When I figure out how to post pictures, I’ll post some of my new bench. I did add it as my profil image if its not to small to see.
-- John, Tennessee
View PurpLev's profile
PurpLev
8534 posts in 3614 days
#7 posted 07-16-2013 12:52 PM
is the top 4” throughout?
4” could be a bit too deep of a hole to hold a holdfast – it keeps the holdfast almost completely vertical and doesn’t allow the holdfast to tilt which is what holds the holdfast in the first place. – you might want to consider counterboring the dog holes from under the workbench 1-2” deep – that might allow the holdfast to tilt enough to grab.
curious – what did you finish the workbench with (that it interferes with it’s functionality so to speak)?
View BigRedKnothead's profile
BigRedKnothead
8513 posts in 1948 days
#8 posted 07-16-2013 01:11 PM
Hey man, My benchtop is 4” thick. As gramercy tools warned, I couldn’t get my holdfasts to work until I reemed(widened) out the bottom of the dog holes a little(under the bench). I used this stepped or “uni” bit. Worked like a charm. -Red
-- "At the end of the day, try and make it beautiful....because the world is full of ugly." Konrad Sauer
View HorizontalMike's profile
HorizontalMike
7749 posts in 2880 days
#9 posted 07-16-2013 01:41 PM
Lots of good advice above. I have also seen where some have even used a hole punch to make a series of pings along and around the holdfast portion that resides in the benchtop.
View Pete Pedisich's profile
Pete Pedisich
139 posts in 2613 days
#10 posted 07-16-2013 01:57 PM
John,
Same thing just happened to me last week – got just a teeny bit of my oil/wax mixture in the holdfast hole and my Gramercy holdfast would not hold. I had roughed them up with 150 grit as well. I then soaked a shop towel in Denatured Alcohol and stuffed it in the hole and twisted it through the other side so it scrubbed the walls and let it dry – bingo, the holdfast held like a clamp!
My top is 3-5/16” (3.3125”) thick.
Good Luck!
-Pete
crank49
#11 posted 07-16-2013 05:35 PM
That reamer trick with the uni-bit is what I tried after reading about it here on LJ a few months ago. Worked good for me. My bench is 3 1/2” thick.
HorizontalMike
#12 posted 07-16-2013 07:06 PM
mis-posted sorry…
redSLED
#13 posted 07-16-2013 09:13 PM
bench dog problem.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2076 days
#14 posted 07-16-2013 09:24 PM
I bought my Grammercy holdfasts in-person in Brooklyn, from Joel Moskowitz.
He showed me how to crosshatch the part of the shaft that goes in the dog holes with 80-100 grit, and strongly suggested it be done, as mentioned several times above. It’s quick and easy, so give it a shot.
theoldfart
#15 posted 07-16-2013 09:32 PM
Good one redsled! lol
