rubber feet
Forum topic by Razorbak91313 posted 07-15-2013 06:00 PM 1490 views 0 times favorited 6 replies Add to Favorites Watch
View Razorbak91313's profile
Razorbak91313
89 posts in 2883 days
07-15-2013 06:00 PM
I have recently started making bandsaw boxes and other small items and have come across a slight problem. I can’t find really small rubber feet or even just thin sheets of that non-slip rubber. The thinnest rubber feet/bumpers are 1.5mm thick which doesn’t sound like much unless you are dealing with a small object that fits in your hand. I have hunted some local stores and the internet and can’t seem to find anything at all. I have used the rubber scrap that is between the little rubber feet on the pad that they come on which is perfect but there isn’t much to it. Anyone know where I can buy adhesived backed non-slip rubber sheets that are between 0.5mm and 1mm thick or precut feet that thickness?
-- Turning good wood into even better wood jewelry. DWWoodCreations.com
View ChuckC's profile
ChuckC
843 posts in 3174 days
#1 posted 07-15-2013 06:03 PM
I usually put those little felt circles on the bottom of little boxes. You can find the rubber and felt feet at Home Depot and Lowe’s.
View ozan's profile
ozan
37 posts in 3461 days
#2 posted 07-15-2013 06:18 PM
View Wally331's profile
Wally331
350 posts in 2264 days
#3 posted 07-15-2013 06:55 PM
You could always use a forstner bit and drill a small recess to fit the thicker rubber feet into. Just an idea.
View Veto's profile
Veto
28 posts in 2068 days
#4 posted 07-15-2013 07:07 PM
They also sell rolls of adhesive backed cork that is easy to punch out with a 1/2” hole punch.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2311 days
#5 posted 07-15-2013 07:13 PM
duraco try the non skid foam and the rubber bumpers. I get very small bumpers from them.
-- Who is John Galt?
View gfadvm's profile
gfadvm
14940 posts in 2929 days
#6 posted 07-16-2013 01:10 AM
I use thin leather and a Harbor Freight gasket punch set. Attach with contact cement. Those gasket punches and contact cement would work well with rubber as well.
