Wood storage, DOs and DON'Ts
Forum topic by Blackie_ posted 07-15-2013 02:50 PM 2189 views 0 times favorited 15 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
4846 posts in 2421 days
07-15-2013 02:50 PM
Needing some advise on storing wood, DOs and DON’Ts, I have been storing all of my purchased woods inside of my air conditioned shop in which has a window unit but it’s not on when I’m not in it. By storing my woods in this kind of environment have an impact on the lumber? Should I be storing my woods on the outside of my shop, perhaps under a lean-to? I do know that the AC does remove moisture from the air when it’s running plus the cooling and warming effect when turning it on and off.
When purchasing the wood from the lumber mill I notice it is always in a non environment controlled warehouse.
Thanks
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
15 replies so far
View NiteWalker's profile
NiteWalker
2736 posts in 2486 days
#1 posted 07-15-2013 02:55 PM
If it’s kiln dried I wouldn’t worry.
View longgone's profile
longgone
5688 posts in 3217 days
#2 posted 07-15-2013 03:09 PM
Randy,
I have lumber storage in two different areas…One is inside my shop that is air conditioned and well insulated. The other storage area is an uninsulated 12×20 shed that has a dehumilifier and a fan but no a/c.
The wood in the shop and the storage shed both seem to do just fine with no problems.
Moisture content of wood in the shop stays around 7-8% and in the shed it levels off around 10%...both are acceptable levels.
My lumber is a combination of kiln dried lumber purchased from the lumberyards and air dried sinker cypress that started out with a 65-70% moisture content.
I think the lumberyards do not climate control their warehouses mainly because of the costs of controlling such a large space that constantly has large doors opening and closing…I wouldn’t want that utility bill.
View Jim Jakosh's profile
Jim Jakosh
20091 posts in 3014 days
#3 posted 07-15-2013 03:16 PM
Just store it flat to avoid warping. Either place should be fine.
View pintodeluxe's profile
pintodeluxe
5569 posts in 2722 days
#4 posted 07-15-2013 03:22 PM
Green lumber needs to be stacked and stickered outside. Let it air dry one year per inch of thickness in a location where a breeze will reach it, but rain will not (a three sided shed for instance). Then kiln dry it to 6-8% m.c.
Kiln dried lumber can be stored in your shop. I have had 1000 l.f. of kiln dried quartersawn red oak in my shop for over a year, and it is still at 6-8% m.c. My shop is rarely heated / air conditioned.
View DocSavage45's profile
DocSavage45
8460 posts in 2751 days
#5 posted 07-15-2013 04:21 PM
Randy,
The people whom I respect have suggested that you bring pieces into the environment to acclimate. This is used for tunge ( sp?) and groove flooring in almost any weather condition. Don’t know what information you have re: Kiln dried vs. air dried, but air dried can be stored outside if it is stickered ( air flow too both sides of the wood) protected from moisture and sun. In my case I did that and found it didn’t do anything for insects! Moved the air dried to a neutral indoor space and treated the area with borax. Still have the results of aggressive ants, and beetles.
George Nakashima stored his slab cuts in a shed , which were air drying vertically. I’m pretty sure it was to keep an eye on the drying .
Even inside your shop the evaporation from one side should also happen to the other especially with long/wide boards. Charles Neil recommends keeping your final cuts in a plastic bag before assembly as any cut to a board releases tension and changes moisture for the different surfaces.
In my case it’s the extremes in humidity and dryness that are causing pieces I’ve had for years to check and crack….grrrrr! I have heat but can’t afford an ac unit that’s big enough, right now.
-- Cau Haus Designs, Thomas J. Tieffenbacher
Blackie_
#6 posted 07-15-2013 06:02 PM
Ok thanks for the comments, reason for the question is that I had a nice piece of Rose Wood warp on me and also a 8 quarter x 4” x 6’ slab of maple do the same thing.
DocSavage45
#7 posted 07-15-2013 06:19 PM
Put it in a plastic bag with some moisture? Sometimes it’s just the tension in the wood cut. I have had 2×4’s bend to look like an archers bow. LOL!
Blackie_
#8 posted 07-15-2013 07:57 PM
Thanks Thomas will do that.
View jusfine's profile
jusfine
2422 posts in 2835 days
#9 posted 07-15-2013 09:46 PM
I have storage racks for solid wood and plywood in the loft of my unheated barn (gets to -40 degrees in winter).
I acclimate the material by bringing it into the heated shop, stickering it (spacers) and wrapping it with a couple blankets for a day or two, then take one blanket off, and after a couple more days, remove the other blanket.
After leaving the lumber for a few more days I will make some test cuts.
If you think of a 70 to 100 degree change in temperature, something is going to happen, cracking, etc.
I wouldn’t think your AC shop will cause a problem for your materials.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View WDHLT15's profile
WDHLT15
1722 posts in 2385 days
#10 posted 07-16-2013 02:08 AM
I would keep it in the shop for sure if you have the space. There will be more consistent temperature and humidity and the wood will be in a more stable environment.
Blackie_
#11 posted 07-16-2013 09:05 AM
I am relieved that I don’t have to make any drastic changes if any at all, thanks to you all, I can set my mind at ease.
View AngieO's profile
AngieO
1267 posts in 2056 days
#12 posted 07-24-2013 02:56 AM
Glad you brought this topic up.
View RussellAP's profile
RussellAP
3103 posts in 2195 days
#13 posted 07-24-2013 04:20 AM
Keep it a foot off the concrete floor, sticker it every 2.5’ never lean it up against anything. If you ever purchase wood from a local sawyer, keep that stuff outside even if it was kiln dried. Not all sawyers dry completely and there might be bugs.
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2264 days
#14 posted 07-24-2013 05:01 AM
awi says you should keep wood stored in a moisture controled environment, you can either get a dehumidifier and keep it running emptying it every so often, or leave the ac unit on.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
Blackie_
#15 posted 07-24-2013 09:23 AM
I have a wall wood rack plus my shop is pier and beam with plyboard flooring so no concrete, so far I’ve had only one bad bow with a slightly twist which was Bubinga, everything else is staying true even with the the AC being turned off at days end.
