leeson motor rewire 220 to 110? ...photos
Forum topic by dunnswoodworks posted 07-14-2013 11:00 PM 2309 views 0 times favorited 5 replies Add to Favorites Watch
View dunnswoodworks's profile
dunnswoodworks
6 posts in 1968 days
07-14-2013 11:00 PM
I have this leeson 1.5 hp. motor thats on a old craftsman planer wired as 220.Can this be rewired to 110.From the top down their is (1 with black wired to it.(2 with no wire attached to it.(3 with no wire attached to it.(4 with white wire attached to it.And finally Green wire very bottom large screw.
5 replies so far
MrUnix
6703 posts in 2194 days
#1 posted 07-14-2013 11:44 PM
It’s hard to read, but the label seems to indicate 205/230V, which means it won’t do 110.. check the tag to confirm (or post a better picture for us!).
View JustJoe's profile
JustJoe
1554 posts in 2033 days
#2 posted 07-14-2013 11:48 PM
You cut off the model number in the pic. You can take the full model # to leeson and search their site. If it’s a very old one, they won’t have the diagram posted but you can email them with the # and they can tell you the specs on the motor. If it’s 110/220 it will usualy say so somewhere on that plate.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View REO's profile
REO
928 posts in 2069 days
#3 posted 07-15-2013 12:26 AM
it would appear that you don’t have user serviceable rewiring available for voltage change. it is still possible but it may require pulling the end off the motor and digging out the connections to the windings so that you can split them. definitely possible but not on the low end of the easy scale.
dunnswoodworks
#4 posted 07-15-2013 01:22 AM
Ok…...thanks guys.I think I will dig out my 1/3 hp motor and put it on there.Shows no where on the plate 110/220 so I am sure I will find a use for it later. Travis
MrUnix
#5 posted 07-15-2013 02:51 AM
From the photo, it’s a model #A6C34DC34A
A google search turns up a few for sale, and they are listed as 208/230V single phase 1.5HP with a 1.15 SF. and running 3450 RPM @60Hz. (2850 RPM @50Hz)
You might be able to open it up and rig it to run on 110, maybe.. but I doubt it. Usually if there is a way to run dual voltages, the MFG will let you know so they can charge more money :)
Anyway, according to Leeson, the model number breaks down to:
A = Auto protectred
6 = NEMA 56 Frame
C = Cap. Start/Ind. run
34 = 3450 RPM @60Hz – 2 pole
D = Drip proof enclosure
C = “C” Face mounting – no base NEMA
34A = internal sequence number and modification level
The good news is that you could probably sell it for a good bit of change.. if you search on that model number, you will find a couple of places selling them for upwards of $200.
