My patented 3 clamp, 4 scrap shooting board
« back to Hand Tools forum
Forum topic by Benvolio posted 07-14-2013 09:57 PM 1019 views 0 times favorited 2 replies Add to Favorites Watch
View Benvolio's profile
Benvolio
148 posts in 1956 days
07-14-2013 09:57 PM
I was in a bit of a sinch this afternoon – out in the garden needing to butt joint two pieces of wood but my pain in the bum chop saw wouldn’t give me a straight enough cut.
So I put my thinking cap on an came up with this little set up. The only provision is that the two thin scraps (on which the stock rest) need to be the same thickness. Other than that, this can be made with any old scrap, to any old size you like!
This turned out to be a super convenient set up, easy to calibrate and gave surprisingly good results.
I’m sure some/most of you will not see this as anything new but to me – I’ve learned that necessity is indeed, the mother of invention.
-- Ben, England.
2 replies so far
Benvolio
#1 posted 07-14-2013 10:01 PM
-- Ben, England.
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3737 days
#2 posted 08-03-2013 11:10 PM
Ben, you may want to read up on bench hooks. That is essentially what you’ve invented there. They are an amazingly versatile tool that you can readily make for your shop.
