Anyone use cam clamps?
Forum topic by Charlie posted 07-14-2013 01:32 PM 1546 views 0 times favorited 4 replies Add to Favorites Watch
View Charlie's profile
Charlie
1100 posts in 2310 days
07-14-2013 01:32 PM
Topic tags/keywords: question
I’m looking at THESE
To use in place of traditional knobs in my easel building project (that I haven’t started yet because I’m ripping out my kitchen floor and redoing it…. laminate sux in a kitchen). The cam clamps would need to hold pieces that slide to hold a canvas. So in the following picture, I’d be replacing the knobs with cam clamps. Would they have enough holding power without being too hard to operate?
View 1yeldud1's profile
1yeldud1
301 posts in 3066 days
#1 posted 07-14-2013 02:10 PM
I have purchased several sets of these and have not been too pleased with the outcome. They didnt work too good in my applications. I ended up having to install a “o-ring” along with the supplied rubber washer to help increase the cam holding power. Wish I would have bought knob style clamps instead. Just my 2 cents worth
Charlie
#2 posted 07-14-2013 02:16 PM
1yeldud1,
good information. Thanks. I’ve never used them. Was interested in hearing about first-hand experiences with them so this helps a lot. Thanks! :)
View Dan Krager's profile
Dan Krager
4033 posts in 2258 days
#3 posted 07-14-2013 03:07 PM
I’ve not had real positive experiences with cam clamps of various sorts. The tension can sneak loose and flipping the lever doesn’t lock down as tight as you expect. Things move. I’ve had cam clamps that pop open when what they’re supposed to hold moves.
If you were building this of hard wood, I would suggest a holdfast type of compression. But, given the situation, knobs are by far the most reliable because every time you use them you become aware of how tightly they are holding. You can make your own with turn buckle type of handle very quickly and efficiently.
http://kragerwoodworking.weebly.com/1/archives/07-2012/1.html
Simply a 3/4×3/4 stick cut at 45 degrees every few inches, hole bored for bolt, counter bored for hex head and pressed into undersize hole. Carriage bolt can be left on surface. Making your own allows you to choose the wood and mix or match colors. These are as strong as any plastic knob!
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com One should always prefer the probable impossible to the improbable possible.
View AandCstyle's profile
AandCstyle
3069 posts in 2281 days
#4 posted 07-15-2013 01:18 AM
My only experience with cams is on the Leigh D4R. They work okay in that application. I don’t know how much torque you need to hold your canvasses in place, but I can imagine that a “slip” might ruin your day.
-- Art
