Honeycomb display shelving thoughts
« back to Coffee Lounge forum
Forum topic by longgone posted 07-12-2013 03:13 PM 1773 views 0 times favorited 16 replies Add to Favorites Watch
View longgone's profile
longgone
5688 posts in 3277 days
07-12-2013 03:13 PM
I am looking for some lightweight material that is a honeycomb design and approximately 1/2 to 3/4 thick and can be cut to 31×14. Years ago I saw some shelving material like this being used at an art show. Can’t seem to find a source for it now.
I participate in shows with my work and have displays set up that use 24 shelves that are 31×14 and made of 3/4” ply. This is the equivalent weight to hauling around 3 sheets of plywood. I am considering routing a bunch of slots in the ply to reduce the weight…but i would prefer the lighter honeycomb type of plastic/plexiglass.
Has anyone run across a product like this? I have called several plastic companies and have not had any luck.
Thanks…!
16 replies so far
View DocSavage45's profile
DocSavage45
8520 posts in 2811 days
#1 posted 07-12-2013 03:24 PM
Greg,
Not sure if this is what you are describing?
http://corporate.evonik.com/en/media/archive/pages/news-details.aspx?newsid=14078
Growing pains? LOL!
-- Cau Haus Designs, Thomas J. Tieffenbacher
longgone
#2 posted 07-12-2013 03:57 PM
Thomas….I am not sure either because so many searches and info sheets did not give photos of the product…and like the old saying goes…a picture is worth a thousand words..
Thanks
DocSavage45
#3 posted 07-12-2013 04:07 PM
I’m thinking from description it is in the plexiglass? Goog luck! Getting heavy, hugh?
Check out commercial companies that produce the complete shelving????
Good Luck,
Going to my money making (occasionally) job now.
View PurpLev's profile
PurpLev
8534 posts in 3617 days
#4 posted 07-12-2013 04:12 PM
you can always make some shelves out of masonite that incorporate the honeycomb concept in the form of a torsion box
also found this:
http://www.plascore.com/custom-lightweight-honeycomb-panels.php
http://www.panel.com/kor-board---light-weight-panels-143/
http://www.superhoneycomb.com/
View Talyn's profile
Talyn
55 posts in 3280 days
#5 posted 07-12-2013 05:37 PM
What your looking for is a(Polycarbonate honeycomb sheet)
You can try here>>> http://www.honeycombcn.com/products/search.html?keyword=polycarbonate+honeycomb+core
-- Harry --- Never Give Up, Never Surrender, www.omwear.com
View john2005's profile
john2005
1768 posts in 2146 days
#6 posted 07-12-2013 06:04 PM
Kinda looking for a similar product for the drain on a waterfall feature I am building. If you find something, please post what it is, and if I come up with one I will do the same. Thx
-- In theory there is no difference between theory and practice. In practice there is.
longgone
#7 posted 07-12-2013 11:16 PM
Thanks for the responses..A couple of places have something that is similar to what i am looking for but it seems their minimum purchase requirement is much more than I need. I need the equivalent of three 4×8 sheets…
Still searching…
DocSavage45
#8 posted 07-12-2013 11:17 PM
Greg,
Is the reason for the acrylic shelves aesthetic, or practical? I was thinking about shelving, transporting and setting it up, strength and design.
My thinking is based on a way I make shelves for storage. I create a rigid frame then add a half inch sheet of plywood to it. I was thinking lightweight? Using the principles of a tension box or hollow core door, you can get some 1/4 inch luane or even an oak veneer plywood. Using steam bending or lamination you can make a curved face for thin shelves and use the iron on veneer edging? It would be similar to an air plane wing? Lightweight but very strong. It would be about same thickness but less weight. And you can finish them to make them pretty or paint them.
Had some driving time to get to work. LOL!
longgone
#9 posted 07-12-2013 11:44 PM
Thomas…that is certainly a way to accomplish it…but i have entirely too much work to do and have no time to spend making that many panels. I am looking for something I can purchase and, at most, cut them to size. I use 24 shelves and they are 31”x14”x3/4”
I am doing this primarily for weight reduction and space saving. I transport my shelves in Rubbermaid containers to keep them from getting scuffed and banged up. By the time I put 8 shelves in a container the weight is the same as a full sheet of 3/4” ply and I use three containers that are less than full due to weight. My thought is to lighten the load so I can fit them in either 1 or 2 containers. The right panels could fit in one large container with considerably less weight and less space requirements. My Ford E150 Van gets filled quickly with everything else that we use at the shows.
DocSavage45
#10 posted 07-13-2013 12:44 AM
Thanks,
I checked out the web page Tayln gave but no specific pricing. Lots of interesting honeycomb. Maybe Blackie or one of the other guys(gals) that go to shows might split your costs?
Best of luck.
View redSLED's profile
redSLED
790 posts in 1861 days
#11 posted 07-13-2013 02:47 AM
Lightweight 1/2” – 3/4” thick honeycomb material.
View Boxguy's profile
Boxguy
2618 posts in 2236 days
#12 posted 07-13-2013 05:08 AM
Greg, try looking at greenhouse materials. They use this stuff. It may be too heavy.
What about one inch blue styrofoam insulation with a glued-on one eighth inch thin wood door skin? 1/4 inch ply strip on edge glued in center of foam shelf would give added strength. Light, quick to make, can be cut on a bandsaw to size after glue-up. Add hole for broom stick for easy transport.
-- Big Al in IN
View Tony_S's profile
Tony_S
857 posts in 3051 days
#13 posted 07-13-2013 10:49 PM
How about
http://www.plyveneer.com/plycorr.html
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View Albert's profile
Albert
508 posts in 3558 days
#14 posted 07-16-2013 03:42 PM
longgone
#15 posted 07-16-2013 04:44 PM
My thanks for all of the ideas and suggestions everyone. I decided to make my new shelves out of 1/2 ” baltic birch and rout out alot of the wood with 1/2” slots to further reduce weight. This should reduce the weight by 50-60% while still having the durability needed for transporting around to the shows.
