clamping a triangle
Forum topic by ElmoSr posted 07-12-2013 01:46 PM 3786 views 0 times favorited 6 replies Add to Favorites Watch
View ElmoSr's profile
ElmoSr
241 posts in 2994 days
07-12-2013 01:46 PM
i am looking for a way to clamp a triangle as for a picture frame,, does anyone have one or a pic of one, done spent to much time surfing for one.
thanks for any help
-- ElmoSr,Ga. Life is Hard by the Yard,,,But a Cinch by the Inch
View Earlextech's profile
Earlextech
1160 posts in 2658 days
#1 posted 07-12-2013 01:49 PM
Strap clamp – or your belt with a spring clamp – or brads
404 - Not Found
2544 posts in 2937 days
#2 posted 07-12-2013 02:43 PM
If I only have one irregular shape to clamp, I lay it out on the assembly table, cramp or screw blocks near to the joints, glue the piece up, lay it back inside the blocks and tighten it all up with folding wedges i.e. opposing wedges.
ElmoSr
#3 posted 07-12-2013 03:59 PM
thanks guys appreciate the help, i am only gluing up one side of the triangle the other side has a flat base was gluing up only the point angle
View PurpLev's profile
PurpLev
8534 posts in 3616 days
#4 posted 07-12-2013 04:02 PM
blue painters tape
View Loren's profile
10276 posts in 3616 days
#5 posted 07-12-2013 04:43 PM
+1 Renners. This approach allows you to fine tune
the pressure to get the joint tight.
View EEngineer's profile
EEngineer
1102 posts in 3581 days
#6 posted 07-13-2013 12:52 AM
I’d take one of these:
and throw away one corner. Then I would make 6 15 degree shims (assuming it is an equilateral triangle). 2 shims per corner, 3 corners and tighten up the band. Voila!
