cutting plexiglass
Forum topic by Monte Pittman posted 07-12-2013 10:54 AM 840 views 0 times favorited 6 replies Add to Favorites Watch
View Monte Pittman's profile (online now)
Monte Pittman
28174 posts in 2243 days
07-12-2013 10:54 AM
Topic tags/keywords: question
I am making some cabinet doors on a project. It will be packed around to a couple shows so I didn’t want to put in glass to avoid breakage. What’s the best way to cut plexiglass on tablesaw? Tape both sides and keep blade very low? Don’t want to screw it up either.
-- Mother Nature created it, I just assemble it.
View NGK's profile
NGK
93 posts in 1816 days
#1 posted 07-13-2013 03:25 AM
Try scoring it like you would regular hard glass, then snapping it.
A saw blade set low creates so much friction it tries to melt the plastic.
A bandsaw would likely work better. Keep your stock moving along.
View Gary's profile
Gary
9293 posts in 3338 days
#2 posted 07-13-2013 03:34 AM
Didn’t we already do this?
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2214 days
#3 posted 07-13-2013 04:36 AM
Google and Youtube, there are hundreds of answers there.
I cut plexiglass quit often. I use about any saw blade that happens to be on my table saw.
View Knothead62's profile
Knothead62
2581 posts in 2866 days
#4 posted 07-13-2013 10:46 AM
????This thread appears three other times.
Monte Pittman
#5 posted 07-13-2013 10:57 AM
Not sure what I did. Computer said it didn’t go. Next thing I knew it went repeatedly. Not my forte in life.
View Rob's profile
Rob
316 posts in 2892 days
#6 posted 07-13-2013 01:33 PM
Monte, I cut Plexiglass on my table saw and haven’t had any problems. I’ve used a 40 tooth freud blade and a 60 tooth blade. Keep the blade low and make sure you hold down the plexi to the table so it doesn’t chatter when you cut it. Makes nice clean cuts.
