Mineral Spirits on wood to sell on web
Forum topic by James posted 07-10-2013 08:12 PM 1321 views 0 times favorited 11 replies Add to Favorites Watch
View James's profile
James
127 posts in 1812 days
07-10-2013 08:12 PM
I’m looking at some lumber on a few sites including ebay. Some of these sellers are wiping the wood down with mineral spirits to give it the sheen of a crappy – in my opinion – finish. Will this evaporate fully by the time it arrives at my house? I want bare wood. If I were to use it for a project and leave it unfinished, would you be able to tell this seller wiped it down with liquids?
-- James - Semper Fi
11 replies so far
View chrisstef's profile
chrisstef
17425 posts in 3032 days
#1 posted 07-10-2013 08:16 PM
It should evaporate within minutes of application James. I don’t think you’ve got anything to worry about. Most of the time I like to wipe my lumber with MS to check for tear out or just simply to see the grain a little bit better before I put a finish on it.
View Loren's profile
10476 posts in 3673 days
#2 posted 07-10-2013 08:25 PM
Don’t worry about it.
James
#3 posted 07-10-2013 10:06 PM
Ok. Thanks guys. It really looks awful the way these guys put the stuff on there. They do it obviously so the buyer can see grain and figure in a picture. But its so wet and disgusting looking when they use on-camera straight-on flashes with point and shoot cameras.
Note: If you’re selling on eBay or CL, pictures are everything. I’ve sold things for 50% more than other identical items because mine were clean, well photographed and well described with phone numbers and contact options. If you post without decent pictures, you’re throwing money away.
View Nomad62's profile
Nomad62
726 posts in 2983 days
#4 posted 07-11-2013 04:44 PM
Your last paragraph says it all, pics rule. Even poor ones are better than nothing, and mineral spirits are much better than water (should never use water). In “real life”, mineral spirits work very well; in pics, maybe not so much but there isn’t a better alternative I’ve heard of yet (opinion?). Leaves no residue, doesn’t damage the wood, evaporates very quickly.
View BTimmons's profile
BTimmons
2303 posts in 2510 days
#5 posted 07-11-2013 04:53 PM
Yeah, it all comes down to the quality of the photos. Thankfully, putting MS on wood hurts nothing. If anything, wiping up the excess helps to clean the surface of dust.
-- Brian Timmons - http://www.BigTWoodworks.com
View PurpLev's profile
PurpLev
8536 posts in 3674 days
#6 posted 07-11-2013 05:04 PM
a lot of lumber and especially turning blocks are usually completely covered with wax to protect it from checking and drying unevenly which in photos look pretty horrible – but will clean nicely and it actually doing good to protect the lumber.
View Dusty56's profile
Dusty56
11819 posts in 3713 days
#7 posted 07-11-2013 05:18 PM
No worries, mon : )
It’s the people that spray water on their offerings that really get to me, especially when they boast that the lumber is already kiln dried .
James
#8 posted 07-12-2013 03:38 AM
Does a little spritz of H2O really make that big of a deal?
View becikeja's profile
becikeja
891 posts in 2838 days
#9 posted 07-12-2013 01:58 PM
Well I have to disagree, if you live in the state of California. I just moved out here from Chicago about a year ago. Went to the store to buy some simple mineral spirits. The can says mineral spirits on it but it’s “California approved” whatever that means. I wiped some mineral spirits over a nice piece of Birdseye maple to get an idea how the grain will pop when finished assuming it would evaporate. This stuff leaves an oily residue behind. A week later this oily substance is still on the wood. I got it off with a lot of rubbing, but I’ll never do that again.
Summary: If it’s not “California Approved” you should be good to go. If it is “California Approved” run.
Dusty56
#10 posted 07-12-2013 05:35 PM
Have to wonder which brand of MS you used that didn’t evaporate and left an oily residue behind.
This brand I’ve used quite often and is also approved in CA.
http://www.amazon.com/dp/B00A3QS9BI#productDetails
Nomad62
#11 posted 07-15-2013 03:36 PM
a spritz of water may leave a bit of a stain on the surface, but that’s easily removed. If a sawyer hoses down wood to make a good pic out of it then it can easily start a staining process that “soaks” into the wood, much more troublesome; if it’s maple, very troublesome. Water really should be kept from wood, it’s a good practice.
