How To "Unroll" Bandsaw Blades Without Getting Cut.
Forum topic by RonInOhio posted 07-10-2013 06:11 PM 3058 views 1 time favorited 19 replies Add to Favorites Watch
View RonInOhio's profile
721 posts in 2799 days
07-10-2013 06:11 PM
Topic tags/keywords: tip
I suppose just about all of us has at one time or another cut ourselves unrolling a bandsaw
blade. Likely they come rolled up like this….
First make sure you have gloves on !
Then open up the roll a little bit and toss it on the floor. If you spread the blade
enough before tossing it against the floor, it will unroll itself and your hands
are clear of all of those sharp teeth.
Spread the blade like so before tossing it on the floor. Also, make sure you have safety eyeglasses
on , leather gloves, and no one is standing near by. Sometimes the blade will hop off or bounce up
off of the floor.
I use to operate a meat bandsaw and had to clean it after everyuse and installed a lot of blades.
It only takes one or two times for those blades to get you before you realize there has got to be another
way. For me this was it.
19 replies so far
View DS's profile
2866 posts in 2355 days
#1 posted 07-10-2013 06:27 PM
Yeh, my bandsaw takes 143” long blades. The narrow ones aren’t much of a problem, but my 3/4” to 1” wide blades have some snap to them.
The first time I got whipped in the back of the head, if you can imagine that.
Harder than unrolling them, is rolling them back up. The thick ones don’t play nice.
View Hammerthumb's profile
2828 posts in 1910 days
#2 posted 07-10-2013 06:51 PM
I have always had problems rolling them up also. Never can remember the trick to it, and end up spending about a half hour trying to figure it out. Just when I’m ready give up, it seems it rolls itself up. Then I try another one and still have problems.
-- Paul, Las Vegas
#3 posted 07-10-2013 07:04 PM
To roll up a bandsaw blade, lay out the blade on floor,teeth up , kneel down and with palms up, grab the
blade with each hand from underneath the part of the blade closest to you. Hands are spread about
the distance of your knees in a crouched position.
Grab blade and fold the blade inward with each hand toward each other while giving the blade a little twist to get the circle and bring each loop into each other.
Hard to explain,easier to show. Its been awhile.
View Dusty56's profile
11819 posts in 3623 days
#4 posted 07-10-2013 07:05 PM
You need to watch the youtube video by Alex Snodgrass representing Carter bandsaw products. He’ll show you the right way to do both without injury to you OR the teeth on the blades : )
#5 posted 07-10-2013 07:12 PM
Here is one way to do it.
And here is Snodgrass showing a better way to open up a rolled blade as well as setting
up a bandsaw. Thanks Dusty .
View Don Butler's profile
Don Butler
1092 posts in 3330 days
#6 posted 07-10-2013 07:37 PM
Personally, my favorite way to open a folded bandsaw blade is to have my wife do it!
-- No trees were damaged in posting this message, but thousands of electrons were seriously inconvenienced.
View DocSavage45's profile
8487 posts in 2777 days
#7 posted 07-10-2013 08:13 PM
Just thinking about putting a 3 tpi blade on my band saw. :>)
It’s not the unwind that I get wrong. LOL!
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Surfside's profile
3389 posts in 2108 days
#8 posted 07-10-2013 09:20 PM
I watched that Alex’s video before when I didn’t know yet how to uncoil band saw blades.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View shipwright's profile
7939 posts in 2733 days
#9 posted 07-10-2013 09:40 PM
I learned on 1” blades for a 42” bandsaw and you didn’t want to be too close to them.
I uncoil them with the “throw on floor” method and I also coil the big ones that way.
Smaller ones are easier to do in your hands.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fibreglass trees.
View DIYaholic's profile
19582 posts in 2610 days
#10 posted 07-10-2013 10:00 PM
I will enlist an underpaid shop assistant to coil/uncoil my BS blades….
If I can find a competent assistant that will work for pennies!!! ;^)
View coachmancuso's profile
259 posts in 1866 days
#11 posted 07-10-2013 10:45 PM
Alex Snodgrass from Cater I find is the best way and it is pretty easy
-- Coach Mancuso
View Bill White's profile
Bill White
4880 posts in 3895 days
#12 posted 07-10-2013 11:06 PM
If I saw you throwin’ my high priced BS blades on the floor, we’d have a lengthy discussion about your tenure or lack thereof with my company.
Right way…wrong way….
Pitchin’ ‘em on concrete ain’t the right way.
OK, I’m a jerk about stuff like that, but those blades are not cheap.
#13 posted 07-10-2013 11:36 PM
......................... and we don’t all have concrete floors.
View wncguy's profile
369 posts in 2247 days
#14 posted 07-10-2013 11:51 PM
I’ve been using the Alex Snodgrass from Carter method since I saw his video (also about setting up the blade on the saw).... agree his method is very good!
-- Any man can be a father, but it takes someone special to be a Dad
View gfadvm's profile
14940 posts in 2625 days
#15 posted 07-11-2013 01:47 AM
I have a concrete shop floor and unroll my small blades by hand. The 1”, 1 TPI go outside and get flung on the grass!
