Vintage Craftsman
Forum topic by phlyers posted 07-10-2013 08:46 AM 599 views 0 times favorited 1 reply Add to Favorites Watch
View phlyers's profile
93 posts in 1717 days
07-10-2013 08:46 AM
Hey guys. New here and received some welcomes so thank you for the welcome! I have an older craftsman TS. It’s model number 113.29920 if this helps. Hopefully someone is familiar with this one so here’s my question. To align the blade to the mitre slot do I loosen the table bolts and shift into position or does the trunion get adjusted for this alignment when the blade is in the 90 degree position.
1 reply so far
View toolie's profile
2114 posts in 2558 days
#1 posted 07-10-2013 10:27 AM
assuming it’s an emerson built 10” CI TS, the trunion gets adjusted when the blade is in the 90 degree position. follow the procedure in this OM. should work just fine:
-- there's a solution to every just have to be willing to find it.
