Bandsaw blades - Is the wood slicer ok to user for ripping and slight curves
Forum topic by DW833 posted 07-10-2013 01:22 AM 1756 views 0 times favorited 8 replies Add to Favorites Watch
View DW833's profile
DW833
212 posts in 1759 days
07-10-2013 01:22 AM
Topic tags/keywords: bandsaw
I’ve purchased a new Grizzly 14 inch band saw with riser kit. Now I want to purchase new blades for it. My first choice is the wood slicer. That blade is considered a resaw blade. Could I also use it for ripping and slight curves?
If that blade is only for resawing, I’ll get it and the timber wolf 3/16 for curves.
8 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2567 days
#1 posted 07-10-2013 01:31 AM
It will work for slight curves but I like to do only straight cuts with my resaw blades as they tend to drift worse after cutting curves.
View NGK's profile
NGK
93 posts in 1788 days
#2 posted 07-10-2013 01:34 AM
Depends on your definition of “slight” curves. Heck, you can cut slight curves with a 10-inch table saw blade. You can also cut slight curves with a regular “hand saw”, often when trying to cut a straight line, especially if the teeth are duller on one side.
Back to the bandsaw. The wider the blade, the bigger will be the smallest diameter you can cut without burning the wood on the back side of the bandsaw blade. When I put a new size (width) blade on a bandsaw, the first thing I do is grab a reasonably thin piece of wood and crowd it to cut the smallest circle possible. That “test” then helps determine which projects are possible with that blade.
Many resaw blades are more expensive than narrower blades. I’d buy two or three blades and save the resaw blade for it’s intended purpose. You can cut 98 percent of what you intend to cut with a 1/4-inch blade. A 3/8 would be my second choice. You can go a limited amount of resawing with a 1/2-inch blade, but often the teeth are too close together, forcing you to go really slow, and chancing to overheat the blade.
View jumbojack's profile
jumbojack
1673 posts in 2501 days
#3 posted 07-10-2013 01:50 AM
Resaw blades are for…...resawing. 1/4” for curves. Resaw blades are not fond of curves.
View PurpLev's profile
PurpLev
8534 posts in 3525 days
#4 posted 07-10-2013 02:24 AM
a 1/2” blade can give you a 2.5” radius cut.
depending on how often and what radii you are planning on cutting – I would keep the woodslicer as dedicated resaw blade and get another narrower blade for radius work
DW833
#5 posted 07-10-2013 02:40 AM
Thanks for the feedback. I’ll stick with resawing for the wood slicer.
View Loren's profile
9776 posts in 3525 days
#6 posted 07-10-2013 03:27 AM
It’s a spendy blade for general work.
View Woodbum's profile
Woodbum
800 posts in 2942 days
#7 posted 07-10-2013 07:09 PM
I personally dedicate a 1/2” Woodslicer blade for resawing and nothing else. I have a Jet 14” bandsaw If you try and cut curves with it, the teeth will lose their factory produced set and wander like hell forever more when trying to use it again as a resaw blade. My fellow Okie gfadvm had it right. Get smaller and cheaper blades for curved cuts , width depending on the radii of the desired curves. IMHO, the Woodslicer, when set up according to their instructions, is the best resaw blade out there for the money. Take care of it and it will last you a long time. (long being a relative term in the world of bandsaw blades)
-- "Now I'm just another old guy wearing funny clothes"
View Surfside's profile
Surfside
3389 posts in 2050 days
#8 posted 07-11-2013 09:41 PM
HWW have a great selection of bandsaw blades and got a blade from there. Haltbar for rough work. It’s easier for you to purchase custom blade.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
