Dual 120 to 220 converter
Forum topic by dmorgantx posted 07-09-2013 10:52 PM 875 views 0 times favorited 6 replies Add to Favorites Watch
View dmorgantx's profile
dmorgantx
70 posts in 3082 days
07-09-2013 10:52 PM
Topic tags/keywords: 120 220 converter 10-30 l6-20
I currently have a Grizzly 0457 Bandsaw wired for 220 (L6-20) that I purchased from CL thinking I would just have a 220 outlet run.
I got a quote for running a 220 or a 20amp 120. Neither option was very feasible from a cost perspective (breaker box needs to be upgraded- couple thousand dollars worth).
At this point- I just want to sell the saw and start over but can’t power it on for anyone to prove it works (I was able to test before buying).
I thought I read here once that there is a gadget where you can connect 2×120 input lines (on different circuits) and it would spit out 220 @ 30amp. Does anyone know about this product?
Conversely I was thinking of trying to get an extension cord from the dryer (NEMA 10-30) but I don’t see anyone making such a cord. I would need at least 15’ to be able to get it to the saw.
Any help / ideas anyone might have would be greatly appreciated!
Thanks
DM
View Doug 's profile
Doug
28 posts in 2092 days
#1 posted 07-09-2013 10:57 PM
You can make your own extension cord that fits the saw outlet on one end and the dryer receptacle on the other. Home centers have everything you need and it will cost around $30 depending on what gauge wire you use.
View Loren's profile
10396 posts in 3647 days
#2 posted 07-09-2013 11:04 PM
You could run an ad on Craigslist offering to trade your
2 hp motor for a lesser amp one. I’m sure you’ll
get some interest as lots of guys have 1 or 1.5 hp
motors on contractor saws and would like a little
more power… and it does make a difference.
View rrww's profile
rrww
263 posts in 2112 days
#3 posted 07-09-2013 11:15 PM
I just made a cord the other day- just pick the ends you need and assemble it yourself. Cost me $40 and 20 mins with all new parts.
View MrUnix's profile
MrUnix
6714 posts in 2198 days
#4 posted 07-09-2013 11:34 PM
I highly recommend AGAINST combining two circuits to get 220.. it’s potentially fatal since each legs circuit breaker will act independently of the other. One alternative is to re-wire the motor for 110V service. That motor will run on 110Vac, it just comes pre-wired for 220. Although, at 110V, you would need a 20A minimum circuit to handle it. As for the extension cord, as Doug said, make one.. it’s easy and everything you need can be found at your local Borg or hardware store.
Shawn Masterson
1325 posts in 1947 days
#5 posted 07-09-2013 11:40 PM
you don’t have to have a new panel.
option 1: change a couple single breakers into doubles and that will make room for a 220 breaker.
option 2: add a sub – panel
option 3: just extend the dryer outlet into the shop. even if you have an electric dryer just don’t use them both at the same time
updating your panel is a great way, but very costly. The three options above are the most cost effective ways to go. this is just my opinion and they are listed in the order I would try. you may want to put the sub panel in the shop to make it easier to add things later. just my $.02
View toolie's profile
toolie
2123 posts in 2627 days
#6 posted 07-10-2013 12:38 AM
i believe this is what the OP was referring to:
http://www.quick220.com/-A220-20D.html
i first came across this in shopnotes magazine. it is UL listed, CSA and OSHA listed. anyone who understands how 220v wiring works will realize that the way this item is configured is as safe as wiring a 2 pole breaker into a panel.
