Cutting Board Jigs
Forum topic by nittanylion posted 07-08-2013 11:48 AM 5354 views 0 times favorited 6 replies Add to Favorites Watch
View nittanylion's profile
nittanylion
59 posts in 3876 days
07-08-2013 11:48 AM
Topic tags/keywords: jig cutting board jigs
Good morning all,
I have thoroughly enjoyed all the insight I have gained from this site. From ideas, to thoughts, to suggestions, it has opened my eyes to more info about all aspects of woodworking.
I have been asked to make quite a few cutting boards recently. I enjoy being able to tweak each one just a bit to make it one of a kind. I am finding that the simple glue ups are very time consuming.
This is where I need your help! Does anyone have any suggestions, photos, plans, or links to effective glue up jigs for cutting boards?
Thanks a ton for your help, I look forward to making a jig to keep up with the demand for the boards!
Have a great day,
Todd
View pmayer's profile
pmayer
1028 posts in 3152 days
#1 posted 07-11-2013 06:31 PM
I would be curious to hear what you come up with on this. I have made many cutting boards, but have not found the glue-up process to be much of a bottleneck. For me the tricky part seems to be trying to get perfect jointed edges on all of the pieces, particularly on super thin accent strips. Once I have that part down, the actually glue-up seems like it takes only a few minutes using normal pipe or bar clamps.
View mds2's profile
mds2
310 posts in 2031 days
#2 posted 07-11-2013 06:46 PM
My grandfather has made over 300 cutting boards this last year. Not bad for a 91 year old. He does use a jig to assemble them. Nothing fancy.
Basically two parallel 2×4’s standing on edge, spaced 12” or so apart. The top edges of the 2×4’s has a stopped dado cut in them to create a little shelf for the strips to sit in. He puts glue on the strips, sets them in order in the dados, and then clamps them together and on to the next one.
pmayer
#3 posted 07-11-2013 06:59 PM
Wow, that is impressive work output for a 91 year old!
How does this approach add speed to the process, compared to just setting them on pipe or bar clamps? Unless I am missing something it just seems like an extra step.
View mds2's profile
mds2
#4 posted 07-11-2013 07:12 PM
I know it helps him keep everything aligned, not sure if it is any faster. It’s what he does and it works. He doesn’t have the upper body strength (torn bicep last year) or the dexterity in his hands like he used to. Watching him work is pretty amazing though. The old adage “first you get good, then you get fast” is true. Even with having to use a walker he runs circles around me in the shop. His efficiency and accuracy are amazing.
I was wrong he made 261 cutting boards and sold 250 of them. I texted him to verify the numbers. Not too shabby at $35-$60 a pop.
View BigMig's profile
BigMig
451 posts in 2700 days
#5 posted 07-12-2013 04:48 PM
I use the “far” fence on my crosscut sled as one side on my clamping area. I put clear packing tape on that fence and clamp direct to it. I clamp on top of waxed/parchment paper to keep glue off the table portion of the sled.
Since that fence is a few inches tall, I cut slots in it that accommodate my bar clamps – but not so many, nor so deep as to affect the rigidity of the sled. Works pretty well, is nice and flat, stable…
-- Mike from Lansdowne, PA
View Brad_Nailor's profile
Brad_Nailor
2539 posts in 4044 days
#6 posted 07-12-2013 05:48 PM
I use a simple jig Click for details to help keep my clamps from wandering around while I am concentrating on the glue up..I do a lot of patterns with different woods and thicknesses, so I usually have quite a few pieces to get glue on and get positioned, the last thing I want to deal with is the clamps moving around.
For end grain boards, I like to use a sandwich set up for gluing, pressing the pieces against a reference flat piece, with another laminated flat bar. Click for details Eng grain slices tend to get a little wonky when you try and glue them up, and that will mess with any pattern alignment you might be trying to do.
