Thien Cyclone Separator
Forum topic by tool248 posted 07-08-2013 09:13 AM 981 views 0 times favorited 2 replies Add to Favorites Watch
View tool248's profile
11 posts in 1774 days
07-08-2013 09:13 AM
I am in the process of building a Thien Cyclone Separator and had a question. I had no problem cutting out the top hat where the dust ports go. However, the bottom baffle is proving to be more difficult. Concerning the 120 degrees angle, do I need to make that tight against the metal trash can or can it just be hanging loosely? I am using a 31 gal. galvanized steel trash can which has ribs and other creases. I can put a piece of weather stripping around the 120 degree part, but was curious if it was necessary since the 240 degree part is going to be open anyways. Thanks.
2 replies so far
View Nicky's profile
695 posts in 4027 days
#1 posted 07-13-2013 05:17 PM
I have about 1/4” space on the 120deg part when sitting in the trash can.
Works like a champ. Its been the best upgrade I’ve made to the shop.
-- Nicky
View Mark's profile
892 posts in 1910 days
#2 posted 07-14-2013 06:21 PM
I’m using a 5 gal plastic bucket and have at least 1/2” all around the baffle. Works like a hot damn.
-- Mark
