Staining an end table top
Forum topic by 5fish posted 07-08-2013 09:12 AM 959 views 0 times favorited 7 replies Add to Favorites Watch
View 5fish's profile
5fish
13 posts in 2073 days
07-08-2013 09:12 AM
Hey LJ’s I’m new to woodworking and Lumberjocks. I have an end table top I’m making out of hickory with a walnut border. I want to stain the hickory with early american stain but i do not want to stain the walnut.Then I want to finish both with a wax. Do i need to stain the hickory before i glue the walnut border on? Will i have a problem with the glue up if i get stain on the sides of the boards? Any tips and tricks would be helpful. Thanks.
7 replies so far
View Clint Searl's profile
Clint Searl
1533 posts in 2599 days
#1 posted 07-08-2013 09:44 PM
Stain the hickory first.
If the glue joint fails, use nails.
Wax ain’t a finish.
View Finisherman's profile
Finisherman
227 posts in 2087 days
#2 posted 07-09-2013 01:56 AM
Stain shouldn’t interfere too much with your glue-up. You can always sand off any stain that gets on the glue joints prior to gluing. Clint’s right. You should stain the hickory before you glue up the project. If you get any of the glue on the surface prior to staining, you’ll likely get glue spots. If you need to use wax as you finish, then please seal the wood beforehand with a coat or two of dewaxed shellac. Otherwise, the wax will enter the grain of the wood and be very difficult to remove at a later date, should this be desired. Better yet, try shellac, lacquer, varnish or a waterborne finish is place of the wax. These are much more durable than wax alone and they don’t require repeated applications in order to maintain their appearance.
View David Dean's profile
David Dean
608 posts in 3137 days
#3 posted 07-09-2013 02:13 AM
5fish do you have a Kregjig I use it for all my edging I dont trust nials.
5fish
#4 posted 07-09-2013 02:52 AM
Thanks for all the help guys. I’m still new to this. I did some sample pieces with different finishes for the customer to look at and they chose the walnut and hickory both stained with early american stain. After i stained the top i applied bulls eye shellac traditional finish and sealer. I’m i on the right track here guys?
Finisherman
#5 posted 07-09-2013 03:49 AM
You’re doing fine.
View pintodeluxe's profile
pintodeluxe
5816 posts in 3051 days
#6 posted 07-09-2013 04:20 AM
I was going to say walnut won’t look much different with early American stain, but it looks like you got it figured out.
Best of luck
5fish
#7 posted 08-04-2013 05:24 PM
Do I need to apply a poly after i put bulls eye shellac on?
