Chess Set
Forum topic by isu1977 posted 07-07-2013 10:30 PM 902 views 0 times favorited 1 reply Add to Favorites Watch
View isu1977's profile
isu1977
44 posts in 2870 days
07-07-2013 10:30 PM
I’m looking for a set of plans for a Chess Set that appeared in Today’s Woodworker Issue 48, which I believe is now out of print. If anyone has a .pdf copy of the plans they’d like to share I would appreciate it. Thanks.
-- Cy - Des Moines, IA
1 reply so far
View redSLED's profile
redSLED
790 posts in 1889 days
#1 posted 08-30-2013 11:33 PM
You might not need the plans – it’s a square chopping board project on top of a box with a drawer. With some routering detail and hand-rubbed oil-based finish no less. Building it to your design and wood choices is always more rewarding, IMO. Maybe buy the desired chess pieces first to determine overall size, unless you want to lathe those yourself.
