How to do maintenance?
Forum topic by Tag84 posted 07-06-2013 06:38 PM 1102 views 0 times favorited 11 replies Add to Favorites Watch
View Tag84's profile
Tag84
573 posts in 2621 days
07-06-2013 06:38 PM
Hi!
I just bought this old mortiser, and was wondering if anybody could help me with how to keep the metal tracks lubricated, and what sort of lubricant i should use?
Help/advice is much appreciated!
-- -Thomas -
11 replies so far
View DIYaholic's profile
DIYaholic
19596 posts in 2639 days
#1 posted 07-06-2013 07:18 PM
As a newbie with little experience, I would suggest….
1) Johnson’s Paste Wax
or
2) Dry Lubricant
A grain of salt should be taken with this advice!!!
View DocSavage45's profile
DocSavage45
8519 posts in 2807 days
#2 posted 07-06-2013 07:22 PM
Looks like wheel bearing grease on it now? White lithium grease might be better. Can use WD40 and 000 steel wool to clean it up. I’ve used my portable belt sander with extremely fine metal parper used in auto body work to rub down the rust, followed by metal polish and after I put a coat of paste wax on the machine surfaces.
What does it do?
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Dutchy's profile
Dutchy
2850 posts in 2133 days
#3 posted 07-06-2013 07:23 PM
117062 posts in 3541 days
#4 posted 07-06-2013 07:38 PM
Grease gathers sawdust.I’d use graphite or paraffin after cleaning off all of that grease.
Tag84
#5 posted 07-06-2013 07:58 PM
Thank alot! Doc yes i put bearinggrease on it :D, becomes a bit messy like Jim says.
Is Paraffin the same as used for protecting your chizles? the oil? I have it in the shop might use that :)
Dutchy bedankt!! zal er naar kijken.
-- -Thomas -
#6 posted 07-06-2013 08:06 PM
Thomas
Some folks just call it wax, it’s use for caning and candle making you can pick some up at the market.
http://www.palmecoltd.com/refined-paraffin-wax.htm
View Loren's profile
10260 posts in 3612 days
#7 posted 07-06-2013 08:17 PM
Can you get Waxlit in Holland? That would work well.
The tolerances in the machine may be so tight you
will need to use grease. If so, find out what
machinests in your country use for greasing mill
crossfeed tables and lathe beds.
Tag84
#8 posted 07-06-2013 08:27 PM
Thanks Jim! i understand it now,
Loren i think this is what you meanhttp://www.maiburg.nl/lijmen/houtverwerkende-industrie/smeermiddelen/ I think it’s exactly what i need Thank you very much :)
-- -Thomas -
View harry1's profile
harry1
524 posts in 2249 days
#9 posted 07-07-2013 10:24 AM
Every year approaching winter I coat the lathe beds, band saw table, drill press table jointer etc with furniture wax polish and never get a rust problem PLUS wood slides beautifully on such a surface.
-- Harry, Western Australia
Dutchy
#10 posted 07-07-2013 08:07 PM
Hello Thomas,
Jim his answer of course is the right one. I did read your question in the wrong way. You asked lubrication of the tracks. My first thougt were the bearings. For so far i know in the past they did it also with a pig thymus (zwezerik)
-- https://dutchypatterns.com/
Tag84
#11 posted 07-08-2013 08:32 AM
I ordered grphite assembly paste, it fitted the description of what i need. Thanks to everyone helping me!
-- -Thomas -
