Good dovetail jig
Forum topic by lateralus819 posted 07-05-2013 07:17 PM 1160 views 0 times favorited 6 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 1857 days
07-05-2013 07:17 PM
I need a jig for doing a few drawers and will likely use this a bit. I’ve seen the PC, Leigh, Rockler. All different types.
What would be the best bet?
View mpsprunger's profile
mpsprunger
22 posts in 1828 days
#1 posted 07-05-2013 07:30 PM
I like my Porter Cable. The learning curve is going to take time for any of these. Once youve matched the correct bit w/ the comb, the depth is cut is correct, the side stops adjusted and the pins are tight ,you will be very proud of yourself
lateralus819
#2 posted 07-05-2013 07:31 PM
Can the porter cable do variable pins/tails?
View James's profile
James
127 posts in 1754 days
#3 posted 07-05-2013 08:50 PM
I have a rockler. It’s decent. They have the fancy pins/tails templates for offset and unique spacing.
-- James - Semper Fi
View jkinoh's profile
jkinoh
95 posts in 1865 days
#4 posted 07-06-2013 01:06 AM
I was in the shop about an hour ago, staring at a Porter Cable model 7116, 24” jig that I bought probably 5 years ago. I watched the video that came with it and that’s about it. Still in the box. Interested? The bad thing is that it weighs a ton. Well, maybe not quite a ton, but a lot.
-- Why buy it for $300 when you can make it for $500!!
View JustJoe's profile
JustJoe
1554 posts in 2006 days
#5 posted 07-06-2013 01:22 AM
I have a porter cable 4216. It doesn’t do variable. It works good for drawers except for the mini template – that’s just a waste. I also have the Leigh Super 18. It does variable. It’s nice. Not sure it’s worth the money I spent on it, but it’s nice. I had an old Craftsman. It didn’t do variable, or much of anything for that matter.
In your search don’t just think “blind dovetails for drawers” – ask yourself what else you’re going to do. Not all of them do through dovetails and eventually you’ll want to try those if you don’t decide to go the hand-cut route.
EDIT: They make them in 12, 18, 24, ++ lengths. If you’re just going to be doing blind dovetails for drawers then ask yourself when is the last time you saw a 24” tall drawer before you decide to shell out an extra couple hundred bucks for the luxury.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
jkinoh
#6 posted 07-06-2013 12:18 PM
I sent these links to lateralus819, but figured I may as well post here too. This is probably the only tool I ever bought that has never been used. Had to make a quick decision as to buy it or not, and for a decent savings. I did, and it’s still in the box, and has been for 5+ years. I have made many drawers, but typically use a box joint I have always used and like, and never wanted to take the time to do dovetails.
There are five pages. Just change the number from 1 to 5 on the url.
http://www.nashportohio.com/Jig1.html
How much? Good question. Haven’t decided. Make an offer (realistic). I have a second floor to my shop with plenty of storage space! I did pull video out and watched after I bought it. Could be an issue finding, but I know it’s here somewhere. Probably still in the VCR (that’s never used…anyone want to buy that?!!)
