Forum topic by CharlesA | posted 07-05-2013 01:25 AM | 4770 views | 0 times favorited | 16 replies | ![]() |
I’ve been looking all over the web for the method of centering a two screw drawer pull without measuring by drawing diagonal lines on the drawer. I think I even saw it referenced here on a project, but I seem unable to find it. If you have a link, I’d really appreciate it. -- "Man is the only animal which devours his own, for I can apply no milder term to the general prey of the rich on the poor." ~Thomas Jefferson |
16 replies so far
#1 posted 07-05-2013 01:27 AM |
http://homeguides.sfgate.com/center-drawer-pull-26593.html -- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium. |
#2 posted 07-05-2013 01:30 AM |
Thanks, JustJoe, but that is not exactly what I’m looking for. What I’m looking for is a method where you draw four diagonal lines (I think) and the intersection of the lines gives you the exact places to drill the holes. It does not involve measuring from the center of the drawer front. -- "Man is the only animal which devours his own, for I can apply no milder term to the general prey of the rich on the poor." ~Thomas Jefferson |
#3 posted 07-05-2013 01:31 AM |
I have mentioned a “no math” method a few times on LJ’s. Here is a link… Basically, if your pulls are 3” on center make a mark 3” in from each corner. Then connect a corner with a mark. Continue connecting the dots until you have 4 lines drawn. Where the lines intersect marks the spot to drill the holes. I actually do the drawing on a plywood jig, then use the jig to drill the holes. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#4 posted 07-05-2013 01:32 AM |
That’s it. Thank you. -- "Man is the only animal which devours his own, for I can apply no milder term to the general prey of the rich on the poor." ~Thomas Jefferson |
#5 posted 07-05-2013 01:38 AM |
Remember to account for an offset if the threads are not centered on the pulls. I use bail pulls for arts and crafts furniture, and the threads in the pulls are often set 1/2” above the centerline of the pull. Good luck. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#6 posted 07-05-2013 01:49 AM |
One can also cut off a couple of 10/32 machine screws and |
#7 posted 07-05-2013 02:45 AM |
If you’re going to measure to draw lines, aren’t you still measuring? |
#8 posted 07-05-2013 02:48 AM |
I had the name wrong, it is “no math” not “no measure.” But it is really quick, partially because the measuring is so simple and completely accurate. Seems to me to be the fastest method for dead on accuracy. -- "Man is the only animal which devours his own, for I can apply no milder term to the general prey of the rich on the poor." ~Thomas Jefferson |
#9 posted 07-05-2013 03:01 AM |
That method is for locating one pull, not two right? (I guess drawing a midline, and then doing it twice; once for each half would work.) -- Steve in Richmond, VA |
#10 posted 07-05-2013 03:07 AM |
It is for locating two. Check out the link from PintoDeluxe above, and he has a picture of what it looks like. The second diagonal is drawn using the center-to-center measurement from the pull. As soon as I read his post, I went out and had the drill hole locations in about 60 seconds. You don’t have to draw the whole lines, just little short lines near the center of the board. -- "Man is the only animal which devours his own, for I can apply no milder term to the general prey of the rich on the poor." ~Thomas Jefferson |
#11 posted 07-05-2013 01:38 PM |
try makeing a jig it works for me. |
#12 posted 07-05-2013 05:09 PM |
Drilled the holes today. Perfect. So easy almost feels like cheating. -- "Man is the only animal which devours his own, for I can apply no milder term to the general prey of the rich on the poor." ~Thomas Jefferson |
#13 posted 07-05-2013 06:58 PM |
I did my whole house with a couple of jigs that I made from 1/4” ply. Set the drill centers on the jig, placed the jig on the drawers/doors (raised molding doors and drawer fronts), marked and drilled. Easy! -- bill@magraphics.us |
#14 posted 07-06-2013 02:01 AM |
I have this jig, I’ve used it many times and it has paid for itself. http://www.rockler.com/product.cfm?page=5877&site=ROCKLER BJ |
#15 posted 07-07-2013 04:01 AM |
While there are simplistic methodologies for laying out the holes for drawer pulls, NOWHERE, absolutely NOWHERE does the axiom of measure twice, drill once apply. You have a finished surface, you’re drilling a hole in it, and once that drill bit hits it you are past the point of no return. Here you use green tape, mark your holes. dubble check your measurements, hold up your pulls to make sure hole centres look good, Step back, scope it out. Only when you are confident drill yer holes. And some of them funky handles don’t have consistent bot holes. Once watched a cabinet installer with years of experience bore a whole ditchen of doors in the wrong place, but he sure was fast doing it. Too much time effort and too much$$ at risk to be anything but absolutely confident and dubble or triple check the measuremts. Cliient just had Fridge door pulls bored in the worng location (wrong size handles on site, nobody checked specs) 2500$ mistake to repair (not by me! thanks be!) Have I ever bored wrong holes, you bet, and I kicked my butt and learned the lesson. I’ll look for quick mehtods to get me to that first layout, but from then on it’s a “step back” and dubble check My install kit includes several jigs, and even when they are used, they get dubble checked. I cannot afford FU’s Pye wrote about the work of craftsmanship as being the work of risk, and in the realm of cabinetmaking, where appearance is paramount, the finishes, handles etc become the end point for the client. Such a simple task as boring holes for handles, thus becomes the be-all and end all for the client, and if it’s a FU, the costs to remediate easily represent any profit you might have made, . Drilling holes for pulls is “bottom line” time, no distractions allowed….. Cowtown Eruc -- Real_cowtown_eric |
Forum | Topics |
Woodworking Skill Share
12033 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4907 |
6697 |
28069 |
CNC Woodworking
212 |
Hand Tools
5413 |
Jigs & Fixtures
1420 |
Wood & Lumber
6234 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4759 |
LumberJocks.com Site Feedback
2201 |
Coffee Lounge
8847 |
