Supernova2 sale - but the numbers don't add up?!?
« back to Woodturning forum
Forum topic by PurpLev posted 07-03-2013 06:23 PM 2194 views 0 times favorited 14 replies Add to Favorites Watch
View PurpLev's profile
PurpLev
8540 posts in 3769 days
07-03-2013 06:23 PM
Woodcraft is having a sale on the Supernova2 chuck with 2 sets of jaws for $199. the ad says ”$100 savings”. now, the supernova2 chuck with 1 set of jaws is running $199, and the additional set of jaws is $50 is bought separately. so where is this $100 in savings coming from?!?
obviously you would also need an adapter nut to get this mounted on the headstock which sets the price another ~$25… but still the machining of this chuck looks pretty good.
while on the subject – those of you with chucks – what jaws do you find you use the most and for what projects (I think the 100mm added jaws set may not be the ideal ‘added’ set for a smaller lathe)?
14 replies so far
View Wildwood's profile (online now)
Wildwood
2409 posts in 2255 days
#1 posted 07-03-2013 08:00 PM
I agree numbers just don’t add up! Have you look at amazon.com or other places?
http://www.amazon.com/TEKNATOOL-SUPERNOVA-CHUCK-WOODWORM-SUPERNOVA2/dp/B0037M8KI2/ref=sr_1_1?ie=UTF8&qid=1372880457&sr=8-1&keywords=super+nova+2
For small lathe this might be a better deal if even if going to upgrade your lathe soon. I know Packard Woodworks and think Craft Supplies sells these chucks and threaded inserts for same price as Woodcraft but would have to pay shipping.
http://www.packardwoodworks.com
http://www.amazon.com/WOODLATHE-CHUCK-WOODWORM-SCREW-INSERT/dp/B003CECDZG/ref=sr_1_3?ie=UTF8&qid=1372880457&sr=8-3&keywords=super+nova+2
Teknatool very good about recommending their chucks by lathe size. Both chucks very popular with woodturners. For a small lathe Nova small dovetail or pin jaws might make more sense.
Do not forget about checking out Nova reconditioned chucks and jaw sets.
http://www.novatoolsusa.com/Reconditioned-Products_c10.htm
-- Bill
16276 posts in 4339 days
#2 posted 07-03-2013 08:02 PM
You could truthfully advertise a $25k Chevy Impala as being a $100,000 savings if you were basing your statement on the cost of going to the parts department and ordering every single piece on the car separately. I suspect that is what’s going on here to some extent.
I almost never use anything other than the stock jaws and/or woodworm screw. It’s hard to imaging needing really big jaws on a mini lathe.
PurpLev
#3 posted 07-03-2013 08:19 PM
I think the added cost is the universal-spanner and the storage box… hardly something I would pay $50 for though , but that is just me.
yes. I think I’ll be going for the recond SN2 with the 2” jaws with an insert totaling at ~130. this will be easier to adapt to other lathes ,and have a better resale value if I ever decide to go a different route (which I doubt would be the case).
Charlie – which baracuda are you using ? the one with closed or open back (is that 2?3?4?)?
#4 posted 07-03-2013 09:16 PM
This is exactly what I have.
PurpLev
#5 posted 07-03-2013 09:19 PM
thanks
Wildwood
#6 posted 07-03-2013 10:14 PM
Only problem have with CSC300c is 9 LBS weight and cannot up-grade thread adapter if you buy a biggeror smaller lathe.
-- Bill
View mpax356's profile
mpax356
74 posts in 2612 days
#7 posted 07-04-2013 01:13 AM
Jaws are such a personal preference based on what you do. If you do a lot of end grain HFs, the 35mm spigot jaws might be useful as they give a great hold on a large spindle. If you do a lot of spindle work on wood too small to fit in the 50mm jaws, consider the pin jaws or the 25mm bowl jaws. I use the 25mm bowl jaws a lot on ornaments, finials, etc.
-- MPax, Atlanta
PurpLev
#8 posted 07-04-2013 01:30 PM
That’s what I thought regarding smaller lathe. I’ll probably lol for small jaws as the project dictates.Thanks for the info.
9 lbs for the baracuda?!? Seems strange seeing that it’s triple the weight of the nova are you sure?
#9 posted 07-04-2013 01:46 PM
I don’t have a small scale to put mine on, but I can’t believe it is that heavy.
#10 posted 07-04-2013 01:49 PM
Oh. I see where he got that. That is the Amazon shipping weight for the whole set (which includes a plastic case, by the way).
Wildwood
#11 posted 07-04-2013 03:54 PM
OOPS PSI catalog says chuck weight only 4 LBS!
Barracuda 4 only weighs 8 LBS.
Still feel they should offer more chuck insert options.
What can I say devil in the details and got them details wrong!
-- Bill
View bondogaposis's profile
bondogaposis
4931 posts in 2471 days
#12 posted 07-04-2013 09:20 PM
When I bought mine last year Woodcraft had the same sale, I bought mine from Amazon for $150. It is just marketing, there is no savings.
-- Bondo Gaposis
PurpLev
#13 posted 07-04-2013 11:34 PM
Just ordered direct from teknatool.the Chuck being larger then g3 I think the 2” jaw set will do just fine for now.
Thanks for all the inputs
View Ron Ford's profile
Ron Ford
209 posts in 1852 days
#14 posted 08-28-2013 10:54 PM
Watch eBay for seller rg woodworker specialties (note that there are _ marks after ‘rg’ and ‘woodworker’ but the editing program here deletes them and makes ‘woodworker’ italics when I try to put them in). He often offers a Nova chuck body with the key and an insert for your lathe (you need to specify which size you need) for $159 with shipping included. I have bought two from him and the service has been excellent.
I have 50 mm, 75 mm, 100 mm and pin jaws for my (four) Nova chucks and find uses for each of them over and over.
Ron
-- Once in awhile I make something really great. Most days I just make sawdust.
