Finishing quest.
Forum topic by Mark posted 07-03-2013 03:03 PM 887 views 1 time favorited 9 replies Add to Favorites Watch
View Mark's profile
Mark
967 posts in 2150 days
07-03-2013 03:03 PM
I’m just about finished a Mission style Cherry end table. I used 1 coat of “teak oil” and 5 coats of water based satin Varithan, sanded with 220g in between. I keep thinking there should be a final coating. Any thoughts or suggestions? Thanks. Mark
-- Mark
9 replies so far
View Finisherman's profile
Finisherman
227 posts in 2025 days
#1 posted 07-03-2013 07:29 PM
Have you considered rubbing out the finish? This is relatively easy to do and involves using some combination of 0000 steel wool, wet-dry sandpaper and or rubbing compounds to remove any defects in the surface and adjust the sheen. Bob Flexner’s book entitled Understanding Wood Finishing provides a detailed explanation of the rubbing out process. Practice the rubbing out process on a scrap board prior to trying it on your project.
View pintodeluxe's profile
pintodeluxe
5784 posts in 2989 days
#2 posted 07-03-2013 07:32 PM
Sounds like you did okay.
I am not a fan of water based products, mostly because of the somewhat lifeless look they impart.
If you are not happy with it, try oil based stain, then sprayed lacquer on your next project.
16278 posts in 4394 days
#3 posted 07-03-2013 07:37 PM
When you say you keep thinking there should be a final coating, do you mean you are just thinking it needs something else, or are you not satisfied with the actual appearance? You certainly don’t need another coating for any practical reason. Anything else you do at this point would simply be to change the look.
View Clint Searl's profile
Clint Searl
1533 posts in 2537 days
#4 posted 07-03-2013 07:56 PM
What makes you think you ain’t done?
View Mark's profile
Mark
#5 posted 07-03-2013 08:01 PM
Fist off. Thank you for your response gents.
Finisherman…I’ve picked up some 0000 SW ad some 350 & 450 WD sand paper and will try that.
Pintodeluxe…I like the water based varnish because it dries so fast. Not having access to a spray booth I’m kinda stuck with the dirty old garage.
Charlie &Clint…I’m trying to get away from the brushed look. I’m hoping a combination of the fine sand paper, the 0000 and the furniture wax will change the appearance for the better.
-- Mark
#6 posted 07-03-2013 08:07 PM
If it looks brushed on, I totally understand. I’ve had pretty good success applying the final coat or two of water-based finish with a foam brush. You might give it a try. Also, I would recommend experimenting with wipe-on oil-based finishes as well. They take more coats, but the coats dry fairly quickly because they’re thin, and the finish never looks brushed.
Finisherman
#7 posted 07-03-2013 08:56 PM
450 grit sandpaper sounds like it might be a little bit too aggressive. I’d try 800 grit wet-dry paper first and see if that does the job. You don’t want to cut through the finish. Also, you might want to use a bit of soapy water with your sandpaper and steel wool. This reduces scratching and keeps the paper from loading up too much. And yes, rubbing out the finish will dramatically improve its look.
Clint Searl
#8 posted 07-03-2013 11:54 PM
Avoid steel wool. Flatten the finish with 320, 400, 600 SiliconCarbide paper on a hard rubber block lubed with soapy water. Finish by rubbing out with auto polishing compound. Then paste wax if you want.
Finisherman
#9 posted 07-04-2013 08:46 PM
You’re right, Clint. I’m so used to using shellac and solvent based lacquer that I forgot about the potential problem with steel wool where waterborne finishes are concerned. Specifically, if you use steel wool between coats of waterborne finish, you’re likely to get black spots in your finish. This is because any stray shards of steel wool that are left behind will rust upon contact with water. In that case, your only recourse will involve stripping the surface, bleaching with oxalic acid and refinishing. Not fun! As a rule, use ultra-fine synthetic pads in place of steel wool with waterborne finishes. Once again, good catch, Clint.
