How to fix a rabbet on a Picture Frame?
« back to Joinery forum
Forum topic by dust4tears posted 07-02-2013 08:07 PM 1430 views 0 times favorited 13 replies Add to Favorites Watch
View dust4tears's profile
dust4tears
397 posts in 2054 days
07-02-2013 08:07 PM
Topic tags/keywords: rabbet frame picture frame
I made a picture frame and I used a bearing rabbetting bit. I thought the allotted space would have been fine, but it isnt big enough.
I have already finished the frame….so, I do not want to ruin it by trying to make the rabbets bigger through trail and error.
My first thought was to cut the glass…and it broke.
Is there an ‘easy’ way to make the rabbets bigger without ruining the already glued up frame? I dont have a bigger bearing rabbet bit than the one I used.
Can you give me a step by step ‘how to’ make the rabbets bigger without running ruining the frame?
-- Ride hard or go home~
13 replies so far
View DS's profile
DS
2855 posts in 2325 days
#1 posted 07-02-2013 08:31 PM
If you already broke the glass, just get the replacement glass to the smaller size for your existing rabbit. (you could get acrylic from HD for cheap as an alternative to glass—though glass itself is fairly inexespensive)
As to the topic, you could fix a rabbit to a picture frame with a regular nail as long as you could get him to hold still long enough to hammer it in without getting bit. Though, I don’t condone violence towards animals. ;-)
View crank49's profile
crank49
4029 posts in 2876 days
#2 posted 07-02-2013 09:17 PM
If you want to make the rabbet bigger, wouldn’t you need to use a smaller bearing.
And, I agree, a regular nail should work on fixing the rabbit.
View bondogaposis's profile
bondogaposis
4601 posts in 2256 days
#3 posted 07-02-2013 09:21 PM
Get a different size rabbet bit or have a smaller piece of glass made.
-- Bondo Gaposis
View Kristoffer's profile
Kristoffer
675 posts in 3121 days
#4 posted 07-03-2013 12:26 AM
Two options that I can think of are….
I can’t remember the name of the plane, maybe “chisel plane”, where the blade is all the way to the front. Might not be a cheap fix, but you’ll have a new tool in the shop.
The only other thing I can think of is placing a piece of material: the same thickness as the frame next to the frame to clamp a straight edge to and just usr a straight bit..
-- Cheers and God Bless
Kristoffer
#5 posted 07-03-2013 12:35 AM
Sorry if the second option wasn’t described clearly. I’m using my phone to enter these comments. If you’d like a clearer description, message me on here or call me (248) 613-2894.
View ChuckC's profile
ChuckC
827 posts in 2840 days
#6 posted 07-03-2013 12:40 AM
Smaller replacement first.
Or, clamp (or use double sided tape) a straight edge to the back of the frame where you want the rabbet to be and use a pattern bit in a router to cut. Do this on all 4 sides.
116905 posts in 3482 days
#7 posted 07-03-2013 01:02 AM
Ditto what Bondo said.
View distrbd's profile
distrbd
2252 posts in 2352 days
#8 posted 07-03-2013 01:05 AM
I would put a smaller bearing on the bit and recut.as crank49 said.
-- Ken from Ontario, Canada
View Gary's profile
Gary
9293 posts in 3338 days
#9 posted 07-03-2013 01:24 AM
And….remember this lesson and check it before glue up next time. That’s how we all learn. You should see some of the reminders hanging around my shop
ChuckC
#10 posted 07-03-2013 01:31 AM
^^ ah, the old saying. Measure twice, rabbet once..
View waho6o9's profile
waho6o9
8099 posts in 2482 days
#11 posted 07-03-2013 01:45 AM
Rabbit plane
bondogaposis
#12 posted 07-03-2013 12:45 PM
One thing I have learned from making picture frames, make the frame first, then take it to the glass shop and tell them cut a piece of glass to fit the frame. Don’t give them any measurements, let them fit it.
-- Bondo Gaposis
View Knothead62's profile
Knothead62
2581 posts in 2866 days
#13 posted 07-03-2013 02:01 PM
“You should see some of the reminders hanging around my shop”
Those are projects on hold pending further modifications.
