flappers inside of wynn filter for cleaning design ideas?
Forum topic by JesseTutt posted 07-02-2013 06:01 PM 1554 views 0 times favorited 6 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
854 posts in 2075 days
07-02-2013 06:01 PM
Topic tags/keywords: wynn filter cleaning
I have cleaned my Wynn filter twice this week by blowing air into it from the outside.
I have seen pictures where people have built a hand crank and flappers inside to knock the dust free.
What kind(s) of material is used for the flapper? How about how much contact it should have with the inside pleats?
View Grandpa's profile
Grandpa
3259 posts in 2640 days
#1 posted 07-02-2013 06:54 PM
I don’t have anything in mine yet and may never but I have thought about it. I think something pretty flexible like a mud flap or a rubber stair tread would work. I don’t think you want to much pressure on the filter cartridge so you don’t damage it. What are you thinking?
View pintodeluxe's profile
pintodeluxe
5620 posts in 2778 days
#2 posted 07-02-2013 06:55 PM
Heavy leather or rubber attached to a metal arm would work.
View toolie's profile
toolie
2120 posts in 2593 days
#3 posted 07-02-2013 08:06 PM
what kind of a DC do you have?
View crank49's profile
crank49
4030 posts in 2936 days
#4 posted 07-02-2013 09:02 PM
Is there a threaded rod or bolt through the center of the cartridge now to hold it down?
JesseTutt
#5 posted 07-02-2013 09:23 PM
I have the Harbor Freight 2HP dust collector. I will need to put a threaded rod through the center of the cartridge to hold the flappers. I was planning on using a 1/4-20 threaded rod that I already have, unless there is a problem with it.
How big have you made your flappers?
Do you stagger them in a spiral?
toolie
#6 posted 07-03-2013 08:21 PM
add this to your DC to keep your cartridge filter cleaner longer:
http://lumberjocks.com/topics/40189
if a pan isn’t available, use a thien baffle plate instead. reportedly works even better than the pan (vortex cone proxy). i have a jet canister atop my 50-850 and i rarely use the internal paddles.
