What does everyone use?
« back to Woodturning forum
Forum topic by coachmancuso posted 07-01-2013 03:45 PM 950 views 0 times favorited 5 replies Add to Favorites Watch
View coachmancuso's profile
coachmancuso
259 posts in 1899 days
07-01-2013 03:45 PM
What does everyone use to finish their bowls? Both when you will use it for a liquid or food and even if you are just going to use it to look at. I am not sure what I am going to do with this bowl but I will be open for everything. Thanks
-- Coach Mancuso
5 replies so far
View Jack Gaskins's profile
Jack Gaskins
46 posts in 2982 days
#1 posted 07-01-2013 04:01 PM
Display bowls – get either wipe on poly or sanding sealer (shellac) built to a shine level that I like.
User bowls for food will get walnut oil blend from Mike Mahoney and some beeswax just to keep put a satin sheen on them. If they will be used for strickly dry foods then they will either get sanded to 1000 grit and have NO finish applied at all OR a shellac matte finish.
-- USAF Ret. 2006
View TheDane's profile
TheDane
5404 posts in 3631 days
#2 posted 07-01-2013 04:16 PM
For utilitarian bowls, I use Mahoney’s Walnut Oil and the Beall buffing system (carnuba). For display bowls, it can be poly, lacquer, shellac, or tung oil with the Beall system as the final step.
View mpax356's profile
mpax356
72 posts in 2460 days
#3 posted 07-01-2013 10:29 PM
I use a minimum of three coats of antique oil. More coats used when I want to build up a shine. I apply liberaly with a rage and let dry a day between coats. Then I buff. My favorite is Minwax Antique Oil which you can buy at any Ace Hardware store. You can’t get it at Lowes of HD.
-- MPax, Atlanta
View SASmith               's profile
SASmith
1850 posts in 2955 days
#4 posted 07-01-2013 10:52 PM
I use salad bowl finish on most of my bowls.
-- Scott Smith, Southern Illinois
View rum's profile
rum
148 posts in 2553 days
#5 posted 07-01-2013 11:38 PM
Walnut oil couple coats of Johnsons paste wax – quick and easy
WaterLox – high wear usage bowls
Lacquer or shellac – extra pretty and shiny depending on wood and expected usage
WoodTurnersFinish – because I like the acronym.. and if I want a quick high gloss finish with close to zero color change.
