My Success Hinges on This
Forum topic by HorizontalMike posted 06-30-2013 06:47 PM 3864 views 0 times favorited 14 replies Add to Favorites Watch
View HorizontalMike's profile
HorizontalMike
7754 posts in 2908 days
06-30-2013 06:47 PM
Topic tags/keywords: hinge type door cabinet door cabinet
In the process of building my next project, a Narrow Amish Cabinet, using published plans in a 1995 Rodale book entitled Country Pine I found what appears to be a “hinging” mistake. The first drawing shows the cabinet door with NO ‘rabbet’. You have to look closely at the bottom right to see the door’s edge. More drawings confirm that lack of door rabbet as well.
Later on, the plans for a 3/8” rabbet on all sides of the door:
What the plans do NOT tell you/me is how to “hinge” this door to the door frame. It calls for a ‘lift-off Parliament hinge’, but fails to show what or how this hinge is mounted. Pictures and drawings show the finials along the outside of the rabbet. That seems to make it impossible to mount the hinge to the frame without putting the hinge screws at the very outer edge of the frame, just asking for tearout/failure.
I have these old ‘Hoosier’ hinges that give me one wing that is 1/4” longer than the other and am trying to get this to work. The problem is that the 3/8” rabbet seems to be forcing the door even farther proud of the frame and keeping me from mounting both sides of the hinge at the same time. If I get one mounted properly then the other can’t be mounted and vise versa.
QUESTIONS:
  • How best to ‘fix’ this situation?
  • Is/are there any internal mounted offset hinges out there that are built for this?
  • Do I need to mortise out part of that rabbeted edge, moving the actual hinge into the edge of the proud door?
  • Would it be possible to glue a small block back into the rabbet (just along the hinge area) so that I have enough to have a more secure area to screw to? Don’t know if I would have to mortise the other side of hinge (frame side) deeper or not.
14 replies so far
View biglarry's profile
biglarry
76 posts in 2682 days
#1 posted 06-30-2013 07:20 PM
Mike
I would forget the rabbet and make a flush mounted door. That way you can use the butt hinge or a wrap around hinge with both looking right for the period.
The only way that I know of hinging a door with a rabbet is with a surface hinge but that would not be keeping with the Amish construction technique.
-- "When the going gets tough, switch to power tools." - Red Green
View Grandpa's profile
Grandpa
3259 posts in 2669 days
#2 posted 06-30-2013 07:34 PM
I believe Biglarry is correct. This hinge and door just doesn’t work does it? Not together I mean.
HorizontalMike
#3 posted 06-30-2013 07:38 PM
I have already rabbeted the door. You can just make it out on the outer underside of the door. This is an earlier image while still working on it. I thought about going flush, however the 3/8” rabbet all around, makes the door a full 1/2” too narrow and too short if I were to ‘trim” off the the rabbeted area.
It beats the heck out of me, because the plans show TWO of these cabinets, the original and a reproduction, and BOTH have tall parliament hinges and rabbeted doors. The only way I can figure this is the frame must be mortised deeper, and the door hinge area either was not rabbeted or filled with a glued block where the hinge can be screwed to. If not, the hinge screws end up right on the edge of the rabbet with nothing to bite to. Still puzzled…
HorizontalMike
#4 posted 06-30-2013 07:41 PM
Grandpa, even the Parliament hinge they call for, is nothing more than a glorified higher quality butt hinge. I have been looking for butt hinges with unequal length wings and can find nothing any better than this old Hoosier hinge, and that at least gives me 1/4”. If it were 3/8” I think I would be in like Flint!
View kdc68's profile
kdc68
2657 posts in 2270 days
#5 posted 06-30-2013 08:44 PM
Compare measurements of your Hoosier hinge with this link posted below…maybe Kennedy Hardware has a hinge for you
http://www.kennedyhardware.com/early-hoosier-butt-hinge.html
-- Measure "at least" twice and cut once
HorizontalMike
#6 posted 06-30-2013 09:06 PM
kdc68: ”...Compare measurements of your Hoosier hinge with this link posted below…maybe Kennedy Hardware has a hinge for you…”
Actually these Hoosier hinges came from Kennedy Hardware. I love that site! It is one of just two websites that I always go to look for accurate reproduction parts. As a matter of fact I have an order from them due to be delivered tomorrow/Monday from KennedyHardware . Ordered more early skeleton key locks, cut nails and hinges. Great stuff!
I also got a couple of their taller butt hinges with finials and will see if they work, but am tending toward using these older Hoosier hinges since they appear (to me at least) to better match the period and Amish style. From what I read in the article/plans, the guy who came upon this original piece, thought that this piece was probably of more recent Amish production, but wasn’t sure.
kdc68
#7 posted 06-30-2013 09:13 PM
Agreed…Another place is Horton Brasses…good luck with the hinges…..
http://www.horton-brasses.com/
404 - Not Found
2544 posts in 2963 days
#8 posted 06-30-2013 11:32 PM
This is the only type of hinge I can think of that would suit your application, a butt casement hinge, though obviously not this one which looks cheap and nasty.
Unless it’s offset, a parliament hinge would have to be inset into the frame by the distance of the edge overlap, and the rabbet filled out to the door edge at the hinges as you stated.
If you bought projection hinges you could cut the leaves at unequal widths and rebore/countersink for screws but you’d still have the same issue with the rabbet.
Bit of a headscratcher alright.
HorizontalMike
#9 posted 07-01-2013 12:45 AM
OK, after searching and searching I have found out what to call what I needed in the way of a hinge.
Geez! it took me forever to up with the correct search term!
They are called 3/8” Inset Hinges.
http://www.homeclick.com/amerock-pk7687m-ae-antique-english-3-8-inset-free-swing-hinge-with-minarets/p-328081.aspx
http://www.pullsdirect.com/amerock-bp7565-pair-of-3-8-inset-self-closing-partial-wrap-hinges/p756002
http://www.thehardwarehut.com/catalog-product.php?p_ref=194299
http://www.rockler.com/product.cfm?page=5136&site=ROCKLER
Been banging my head on this one so much that on this first of two or three Amish Narrow Cabinets, I will probably just use my existing hinges, mortising the frame deeper and filling the door rabbet with a small glued block.
I wonder what was actually available in hinges from ~1850—1900s in order to try and be period specific? Hmm…
kdc68
#10 posted 07-01-2013 01:13 AM
Another source for period specific hardware
http://www.houseofantiquehardware.com/site/reproduction/renovators-hardware.html
18149 posts in 1850 days
#11 posted 07-01-2013 01:57 AM
I use that style of hinge often and I get them from amazon.com from amerock. I thought you wanted something that hid the hinge.
View Christophret's profile
Christophret
150 posts in 1995 days
#12 posted 07-01-2013 02:04 AM
Mike, I think your overthinking it.
Whatever happened to shooting from the hip and using gut instincts?
-- I cut it twice and it's still too short!
View tefinn's profile
tefinn
1222 posts in 2431 days
#13 posted 07-01-2013 02:19 AM
HM – If you go with the 3/8 overlay hinges, they’re readily available at the Orange and Blue big box stores. You may not have as many color/finish choices, but you won’t have to wait on them.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
HorizontalMike
#14 posted 07-01-2013 01:33 PM
firefighterontheside, yeah, I want the hinge “pin” exposed but the wing mounting hidden.
Christophret, I understand the shootin’ from the hip thing, but I am trying to maintain as much accuracy as I can when ‘trying’ to build older period pieces. The next thing I am going to do with this cabinet is to milk paint it and beat it up, and repeat!... That is where my “gut instinct” comes in… We’ll see how THAT goes. ;-)
tefinn, I already checked my local HD and the selection of any hinges were minimal, and all were pretty much contractor types for full sized house doors and the like. Have not shopped much at Lowes, as the nearest one is ~35miles and not in the same direction as our normal weekly shopping.
Thanks for all the suggestions folks!
