wax covered wood
Forum topic by JUC posted 06-29-2013 09:25 PM 1631 views 0 times favorited 5 replies Add to Favorites Watch
View JUC's profile
JUC
116 posts in 1887 days
06-29-2013 09:25 PM
I just purchased some 2” sq [more or less] rosewood 24” long. It came covered in wax. I do not want to run this through my tools. What have you all done to remove the wax?
Thanks for your help!!
Jeffrey
-- If no one will ever see it, all the more reason to make it right
5 replies so far
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2853 days
#1 posted 06-29-2013 10:18 PM
The wax will only improve the ease of planing
Wax is used as a lubricant
If your worried, a cabinet scraper will take it off
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View JUC's profile
JUC
#2 posted 06-29-2013 11:11 PM
Thanks Jamie, This is a thick wax not like a past wax. I think I will try to scrap it off.
Jeffery
View papadan's profile
papadan
3584 posts in 3365 days
#3 posted 06-30-2013 12:07 AM
That wax was put on the wood to control the drying process, scraper is the right way to remove it. If the wax gets on you tools it will keep getting back on the wood and cause problems with finishing.
View JUC's profile
JUC
#4 posted 06-30-2013 12:34 AM
Thanks Papadan, that sounds about right. So if the wax is there to control the drying process, what moisture content should I be looking for before I start to use the wood?
Jeffrey
View Tony Strupulis's profile
Tony Strupulis
260 posts in 3120 days
#5 posted 07-02-2013 12:17 AM
That wood is green. As soon as you scrape the wax off it, it will begin drying very quickly. Be prepared for it to crack. When I get a piece that is dipped in wax, I scrape the wax off the face grain sides and let it dry slowly. If you expose the end grain, it will dry quickly.
-- Tony - http://ravensedgetoolworks.com
