1/4" Overlay hinges for frameless cabinets?
Forum topic by 1thumb posted 06-29-2013 06:14 PM 1179 views 0 times favorited 4 replies Add to Favorites Watch
View 1thumb's profile
1thumb
89 posts in 2356 days
06-29-2013 06:14 PM
can’t find them. maybe i should of looked before i built cabinets and doors?
View kdc68's profile
kdc68
2691 posts in 2476 days
#1 posted 06-29-2013 06:21 PM
1thumb….maybe what you need is here….??....good luck
v
http://woodworking.rockler.com/c/frameless-overlay-hinges
-- Measure "at least" twice and cut once
1thumb
#2 posted 06-29-2013 06:23 PM
been there, done that kdc
edit: but upon further review, I may be able to use half overlay. Pic and description of overlay hinges on page linked here. http://www.rockler.com/product.cfm?page=25382&site=ROCKLER, show a 3/16 gap between doors when using half overlay. If material is 3/4 thick, depiction shows an overlay of one half of 9/16 per door. Pert near a quarter
View Loren's profile
10477 posts in 3847 days
#3 posted 06-29-2013 06:55 PM
Standard overlay is a little more than 5/16” – I think
1/4” is within the range of adjustment of a standard
half-overlay cup hinge, but you can tweak the drilling
distance a little on the door, maybe 2mm either way.
Standard drilling distance for a 35mmm cup hinge is
the center of the hole is inset 23mm from the edge
of the door. You can try 21mm for a little less overlay
or 25mm for a little more. Make mockups to check
for problems before committing to drilling a door though.
1thumb
#4 posted 06-29-2013 06:57 PM
Thanks Loren, sounds close enough. I thought half overlay was 3/8, then adjust the gap. Thanks again.
