Saw blades
Forum topic by BigJerryWayne posted 06-29-2013 05:37 PM 833 views 0 times favorited 8 replies Add to Favorites Watch
View BigJerryWayne's profile
BigJerryWayne
138 posts in 2007 days
06-29-2013 05:37 PM
Topic tags/keywords: question blade miter saw tip
I was wondering about tear outs on cuts. Right now I am using a 40 tooth blade on my Craftsman 12” compound miter saw. It is what was on the saw when I bought it. What do I need to look for in a blade to cause less tear out? More teeth, angle of teeth or something else?
-- An oak tree is just a nut that stood it's ground.
8 replies so far
View Sheila Landry (scrollgirl)'s profile
9220 posts in 2824 days
#1 posted 06-29-2013 06:02 PM
Sorry – I didn’t see that this was a miter saw. I guess my head is thinking “Scroll saw!” ;)
Sheila
-- Designer/Artist/Teacher. Owner of Sheila Landry Designs (http://www.sheilalandrydesigns.com) Scroll saw, wood working and painting patterns and surfaces. "Knowledge is Power"
View waho6o9's profile
waho6o9
8099 posts in 2481 days
#2 posted 06-29-2013 06:05 PM
Maybe make a zero clearance fence for your miter saw?
View kdc68's profile
kdc68
2638 posts in 2181 days
#3 posted 06-29-2013 06:07 PM
A blade with 60 or more teeth would be considered a crosscut….An alternate top bevel (ATB) and a negative hook angle are also considerations in a crosscut blade that help eliminate tear out
-- Measure "at least" twice and cut once
View MrRon's profile
MrRon
4628 posts in 3147 days
#4 posted 06-29-2013 06:38 PM
Tearout can be caused by blade runout and incorrectly set teeth on a blade. If your saw is set up properly and you have a good crosscut blade, tearout should be minimal ay best. There will always be variations in blade set and runout with consumer grade tools.
View teejk's profile
teejk
1215 posts in 2588 days
#5 posted 06-29-2013 07:23 PM
When I see excessive tearout on a miter saw cut I do some clean-up and re-tune the blade 90 degrees to the saw table (doesn’t seem to require much deviation to produce that “fuzz”).
View Bill1225's profile
Bill1225
125 posts in 2303 days
#6 posted 06-29-2013 07:33 PM
I use diablo or cmt itk96 tooth blades lately on work trim saws ( they are good value around 50-60$)and forrest chopmaster or amana in the shop (100-120) the cheaper blade can deflect slightly if you push there feed rate
View knotscott's profile
knotscott
7871 posts in 3279 days
#7 posted 06-29-2013 07:57 PM
Saw blade tips
It’s important to get good quality blades that have good steel, precision balance, good carbide, etc….once you clear that hurdle, more teeth typically means a cleaner cut if all else is equal, but there’s never a free lunch… it also means more resitance, more tendency to burn, slower cut, generally higher cost, etc. The cleanest cutting blades will have a high tooth count (typically 80-90T for a 10” or 12” blade) and a HI-ATB grind, which is the cleanest slicing grind available, but also has the shortest edge life….that combination should leave the least amount of tearout possible in a saw blade. If you keep it clean, it should still offer pretty good edge life for a hobbyist. You may also find a that a good ATB grind on a high precision blade with a high tooth count will also do very well, and should give a little longer edge life.
BigJerryWayne
#8 posted 06-30-2013 07:30 PM
Thank you for all the input. I just came in from Lowe’s where a new Dewalt 96 tooth blade just happened jump in my cart.
Now to try it out.
