Improving a joint
« back to Joinery forum
Forum topic by drainyoo posted 06-26-2013 07:47 PM 1618 views 0 times favorited 35 replies Add to Favorites Watch
View drainyoo's profile
drainyoo
26 posts in 1790 days
06-26-2013 07:47 PM
Topic tags/keywords: bench joint joining modern
I’m designing a bench that I’m planning to build soon, and it’s pretty much complete, except for one joint that I’m too sure on yet. If you look at the image below, the joint in question is where the solid part of the bench meets the slats. Right now I have a supporting piece (visible in the side image) on the underside that joins the two, but this feels flimsy to me. Is there a better, stronger, cleaner way of joining the slats and the solid board? Thanks in advance!
35 replies so far
View Tennessee's profile
Tennessee
2870 posts in 2508 days
#1 posted 06-26-2013 07:53 PM
Boy, there will be about a thousand replies to this. For me, if I was to build this for my shop, I think I would do a large surface lap joint with the slats on the top half of the joint, glued, screwed and plugged if possible to the bottom half. You need to make it almost as one. It might also be a good idea to keep the support brace underneath at the joint, glued. I’m assuming at some point you will be going back and forth with some motion, (sanding, planning, etc.) on the top so it will have to stand the back and forth movement.
View pintodeluxe's profile
pintodeluxe
5653 posts in 2807 days
#2 posted 06-26-2013 07:54 PM
Make the whole length a glueup. Solid on one side, and slatted on the other. So some boards would run the entire length of the bench, and other boards would only run part way across. This will allow the whole top to be run through the planer for uniform thickness.
View Mosquito's profile
Mosquito
9302 posts in 2286 days
#3 posted 06-26-2013 07:56 PM
My initial thought was the same as Willie’s ^
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View bondogaposis's profile
bondogaposis
4717 posts in 2345 days
#4 posted 06-26-2013 07:56 PM
Yup, that’s how I would do it.
-- Bondo Gaposis
drainyoo
#5 posted 06-26-2013 08:04 PM
Thanks guys! But with a glueup wouldn’t the “solid” part still have visible stripes? I would like that solid area to also look like a solid piece of wood.
View UpstateNYdude's profile
UpstateNYdude
916 posts in 1976 days
#6 posted 06-26-2013 08:09 PM
M&T into the solid piece and evenly space M&T into a breadboard joint at the other end would make it pretty solid, that is the only other way I can see it being done other then the aforementioned above.
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
drainyoo
#7 posted 06-26-2013 08:18 PM
Thanks Nick. These are two good options, but it seems like they’re complex and might be out of my skill range. Don’t even think I have the right tools to do it the right way. I’m relatively new to woodworking and this is one of my first projects, but I’m learning as I go. Your suggestions definitely made me aware of better techniques that I wouldn’t have thought of. I’m going to thinking about it more, but I might just make the entire top a solid piece of wood.
Mosquito
#8 posted 06-26-2013 08:19 PM
the stupidly expensive route would be to get a slab the size you need, and rout out the slats :-P
But yes, it could leave visible strips, depending on wood selection (and realistically, it would be dang hard to get that much grain to match).
What about doing the lamination for all of it, and putting a single sheet/board recessed into the top of the solid end?
Just throwing ideas out there
Also, curious what kind of a bench it is (sitting/workbench) and the size in question (especially thickness)
View crank49's profile
crank49
4030 posts in 2964 days
#9 posted 06-27-2013 12:01 AM
I’m on board with the one big glue up crowd.
Now, if you want the “solid end” to look like one piece of wood, you could apply a veneer top layer on there.
That starts to make it more interesting because now you will have a bunch of strips of one thickness on one end and a step down to accommodate the veneer on the other end.
But bottom line, that butt joint with the backer board tacked under is gone, as it should be.
18149 posts in 1850 days
#10 posted 06-27-2013 12:12 AM
Use a piece coming up from the stretcher right under the butt joint and at the same location at the other end. Make sure the stretcher is pretty strong to help support the weight of the seated.
View Loren's profile
10373 posts in 3641 days
#11 posted 06-27-2013 01:25 AM
dowels.
#12 posted 06-27-2013 01:26 AM
Blind sliding dovetails.
#13 posted 06-27-2013 01:30 AM
Scarf joints fixed with glue and screws. A ramped
router jig could be used to cut slanted recesses
in the underside of the solid board. A 1:5 ratio
on the scarfs would expose a lot of long grain for
glue surface area.
View Howie's profile
Howie
2656 posts in 2916 days
#14 posted 06-27-2013 01:39 AM
Will not know until you try. That’s the way we all learn.
My choice would be the M&T like others have pointed out.
JMHO.
-- Life is good.
drainyoo
#15 posted 06-27-2013 01:49 AM
You folks are awesome. A lot of great ideas here. Adding support from the stretchers seems interesting and the easiest for me. The dowels are also interesting. How long would the dowels need to be?
For the M&T technique, what kind of tools would I need to cut that? I assume the fit has to be perfect.
showing 1 through 15 of 35 replies
