Burning Wide Lines on a Lathe
« back to Woodturning forum
Forum topic by doubleDD posted 06-26-2013 12:44 AM 3731 views 0 times favorited 17 replies Add to Favorites Watch
View doubleDD's profile (online now)
doubleDD
7008 posts in 1912 days
06-26-2013 12:44 AM
Hey LJ’s, I am working on the lathe with a new project and would like to know if there is a easy way to put a 1/4’’ or larger burn line ( band )on it. I use a wire all the time making thin lines but what about anything wider? Any help would be welcomed. Thanks Dave
17 replies so far
View Jim Jakosh's profile
Jim Jakosh
19943 posts in 2975 days
#1 posted 06-26-2013 12:54 AM
What if you used a 1/4” wide band and held it in a shallow groove made by a parting tool? the run the lathe up real fast and see if it burns it full width.
doubleDD
#2 posted 06-26-2013 01:04 AM
Hey Jim, I used a 1/4’’ parting tool for the groove and tried a 1/4’’ bar for the burn, but didn’t work well. That’s what I looking for is a flexible band of something with enough strength to do it.
View Jimbo4's profile
Jimbo4
1578 posts in 2632 days
#3 posted 06-26-2013 01:15 AM
Did you use the edge of the parting tool with the lathe at high speed. I have a 1/8” parting tool, and if I don’t leave room for the edges it will burn.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
doubleDD
#4 posted 06-26-2013 01:23 AM
Jimbo, yes That was my first idea to use the edge of the parting tool. At 2600 rpm it would give me a small burn on either side but the center gets a shine to it.
View REO's profile
REO
927 posts in 1943 days
#5 posted 06-26-2013 02:36 AM
Doing it the way you have there is little contact surface and a whole lot of heat sink. use a thin strip of material that will partially wrap the work. Hang on and be careful how much you wrap! it will grab if there is a lot of pitch! use a piece of strapping split in half lengthwise. don’t grab directly on to the strap possibly use a vise grip on the far end. the strap is stiff enough that it wont wrap on its own if it gets away from you.
doubleDD
#6 posted 06-26-2013 02:51 AM
Hi REO. Are you referring to the strapping on large cartons or pallets as they use for shipping ? That sounds like that might work.
View mpax356's profile
mpax356
72 posts in 2361 days
#7 posted 06-26-2013 03:42 AM
You might be better off with painting or dying a band. You could use a strip of oily exotic wood but you probably will not get the smooth band you are looking for.
-- MPax, Atlanta
View Wildwood's profile
Wildwood
2203 posts in 2004 days
#8 posted 06-26-2013 09:50 AM
I paid lot less for woodburning kit like this several years ago still thinking about becoming a fine artist one day. Really, think can do more damage with a pencil torch.
http://www.walmart.com/ip/Deluxe-Woodburning-Kit/11045676
If want to serious burning wood and do not mind spending a few more bucks for tools & equipment read what this woman has to say then check her web site turningmaven:
http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=turning&file=articles_769.shtml
http://turningmaven.com/
-- Bill
View bondogaposis's profile
bondogaposis
4524 posts in 2220 days
#9 posted 06-26-2013 12:26 PM
I think this is most often done w/ a small torch like this one.
-- Bondo Gaposis
doubleDD
#10 posted 06-26-2013 01:23 PM
MPax. Bill, Bondo, these are all good ideas. I may have to experiment and try them. MPax, I have painted stripes on turnings before, works well, just trying to do it more traditional. Bondo, Bill, will try these methods if 1/4’’ thin band strip as others have mentioned doesn”t work.
Jimbo4
#11 posted 06-26-2013 03:59 PM
Dave – What about a thin strip of cane or bamboo ?
Edit: Wait! My synapses just reconnected! Forget the above material, it will probably catch fire! ;o(
Shawn Masterson
1324 posts in 1818 days
#12 posted 06-26-2013 11:18 PM
I use Brazilian cherry ripped to the desired width and rounded like a bead moulding. I would imagine any hard wood would work, the harder the better.
View Gopher's profile
Gopher
27 posts in 1815 days
#13 posted 06-27-2013 02:31 AM
Small samples of formica or corian work great, just stack them to width and hold tight and turn fast. Neat trick. try it.
-- Ted T. Aiken S.C.
doubleDD
#14 posted 06-27-2013 03:12 AM
Shawn, your saying wood on wood should burn it, worth a try. Gopher, I see your point about the edges of formica, sound like a neat trick, may have to try it. Hope to try some of these posted tips tomorrow.
View mtenterprises's profile
mtenterprises
933 posts in 2562 days
#15 posted 06-27-2013 10:46 AM
Yes the wood on wood will work, fire by friction my friend. You may have to support the back side of your project as you press a piece of end grain hardwood on to it but you can get wide burns this way. And yes you can have a fire if you get a bit over exuberant so clean away all your chips.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
