HVLP compressor
Forum topic by MrRon posted 06-25-2013 06:08 PM 1192 views 0 times favorited 7 replies Add to Favorites Watch
View MrRon's profile
MrRon
4988 posts in 3361 days
06-25-2013 06:08 PM
Topic tags/keywords: spray gun
Has anyone thought about using a common household vacuum cleaner as an HVLP sprayer? Vacuum cleaners seem to be able to supply a large volume of air. I remember years ago, vacuum cleaners came with a sprayer attachment that worked on the syphon principal.
7 replies so far
View Earlextech's profile
Earlextech
1162 posts in 2809 days
#1 posted 06-25-2013 06:13 PM
Yes MrRon – everyone has.
View Tennessee's profile
Tennessee
2880 posts in 2632 days
#2 posted 06-25-2013 06:16 PM
The problem is air is compressible, and a vacuum cleaner exhaust is lousy at compression. It uses non-positive fans to develop the air movement, so slippage is inevitable and unwanted.
View crank49's profile
crank49
4032 posts in 3089 days
#3 posted 06-25-2013 06:46 PM
All of the “HVLP” sprayers on the market that I am aware of use fans to develop pressure and hence, air flow.
Well, all but the ones that connect to a regulated and diluted compressed air line.
I have worked with equipment that can develop 7 psi pressure with a fan and using multiple stages you can develop thousands of pounds of force with fans.
But, I have wondered the same thing about the old “Electrolux” paint sprayers. I think I even posted the same question on here a couple years ago.
View pintodeluxe's profile
pintodeluxe
5741 posts in 2931 days
#4 posted 06-25-2013 07:00 PM
Whaaaaa?
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2228 days
#5 posted 06-25-2013 07:14 PM
Mr. Ron,
Earlex is being funny… HVLP Turbines ARE vacuum motors. One of the most famous OEM’s is Ametek...
View Bill Davis's profile
Bill Davis
226 posts in 4042 days
#6 posted 06-25-2013 09:28 PM
Years ago, don’t remember exactly when, there was a DIY HVAC article in Fine Woodworking mag using a vac motor similar to one of these motors from Grainger.( http://www.grainger.com/Grainger/vacuum-motors/definite-purpose-ac-motors/motors/ecatalog/N-lrw)
So it is not a far fetched idea and if I were ever tempted to go HVLP that’s how I would do it.. In fact here is a reprint.
http://books.google.com/books?id=OoLmzPO-rikC&pg=PA70&lpg=PA70&dq=build+your+own+HVLP+fine+woodworking&source=bl&ots=LI8MDpw3xB&sig=V1sYNzCcOUsIjnDIwfNTmibOJiI&hl=en&sa=X&ei=0ArKUfGOGcqAygHokoHYAw&ved=0CG8Q6AEwCA#v=onepage&q=build%20your%20own%20HVLP%20fine%20woodworking&f=false
View dhazelton's profile
dhazelton
2789 posts in 2415 days
#7 posted 06-25-2013 11:36 PM
I have a folder with a copy of that Fine Woodworking article because I was going to build one once upon a time. But that was when HVLPs were a small fortune. They are relatively cheap now and it probably is only worth it if you want to experiment and already have the vacuum motor and a gun. But do it – I’ve always wondered how it would work.
