Finishing recommendations for a beginner
Forum topic by dschlic1 posted 06-25-2013 05:22 PM 2444 views 1 time favorited 14 replies Add to Favorites Watch
View dschlic1's profile
dschlic1
442 posts in 2210 days
06-25-2013 05:22 PM
Topic tags/keywords: question oak finishing
I am building a cabinet that will function as an AV Center. Most of the cabinet is Red Oak plywood, and the drawer boxes are Baltic Birch plywood. The fronts of the drawers and some of the stringers are solid Red Oak. I would like some recommendations on finishing. I would like to have a semi-gloss or a satin finish. Also the oak will have to be stained slightly.
I work out of my garage so I do not have a dedicated paint area. Also I do not want to invest in expensive painting equipment for a one time project. I also like in west central Florida so the days are hot and humid.
The first consideration is whether to use oil based stains and finishes or water based. The faster drying time of the water based finishes might help with dust adhesion, put appear to be more difficult to apply.
The second consideration is the method of application. Among them brush, or wipe-on. I do not have a large air compressor so spraying looks to be out of the question.
14 replies so far
16281 posts in 4458 days
#1 posted 06-25-2013 05:32 PM
Oil based stain and wipe-on poly are pretty hard to mess up. Water-based brush-on poly is pretty easy to apply as well. The deciding factor for me would be the look you want. Oil-based tends to add a warm, yellowish tone, while water-based has a clearer, almost blue-ish tint.
Whatever type stain you decide to use, just practice on scraps first so you will get the hang of how to apply it for the color you want. Sometimes, if I really want a dark version of the color I’m using, I’ll brush it on thickly before wiping away the excess. Other times, if I want something lighter, I wipe it on sparingly with a rag.
View zzzzdoc's profile
zzzzdoc
550 posts in 3243 days
#2 posted 06-25-2013 05:37 PM
Tough to mess up wiped-on Waterlox also, plus it looks nice and is pretty durable. But the rubber/plastic feet of a TV on it would react with it. On the other hand, if the TV just stayed there, who cares.
And it works well in West Central Florida ;)
-- Before you criticize someone, you should walk a mile in their shoes. That way, when you criticize them, you're a mile away and you have their shoes.
View pintodeluxe's profile
pintodeluxe
5819 posts in 3053 days
#3 posted 06-25-2013 05:40 PM
I now use gravity feed HVLP spray guns exclusively, but if I were to do a project without spraying I would brush on shellac. You will spend some time sanding between coats, and the final coat will need to waxed with #0000 steel wool.
dschlic1
#4 posted 06-26-2013 12:26 AM
Just did my first glue up of a drawer box. Simple four pieces to glue and the Titebond was drying before I finished! I going see if I can get a small amount of each and paint a test block. Any recommendations on brands?
View Clint Searl's profile
Clint Searl
1533 posts in 2601 days
#5 posted 06-26-2013 08:30 PM
Waterborne poly applied with a soft bristle brush is unbeatable. I like Varathane floor finish.
View redSLED's profile
redSLED
790 posts in 2133 days
#6 posted 06-26-2013 10:25 PM
My opinions are as follows.
Your AV centre will not be eaten on like a dinner table, so you only need a minimal finish coat (wipe-on), or more than that if you want a 100% even, noticeable sheen everywhere (brush-on 3-4 coats). Put a lot of coats on if you think your drunk red-wine spilling friends are coming over once a week, or if your significant other leaves marks everywhere because of their constant greasy moisturized hands. Kids in the house, and allowed to touch your AV centre?—> 3-4 coats.
There is not really any level of difficulty difference between applying oil or water-based stains or finishes.
CharlieM above already provided the finished colour tone differences truth of oil based finishes vs. water based. However, I find that the vast majority of people cannot actually discern the extremely slight bluish colour tone of cured water based finishes. Make that 99.99999% of everyone if there’s a stain underneath.
For DIY carpentry in a garage, there is no point considering spraying finishes with an air compressor unless long term productivity and MANY projects and profit are your objectives – it’s just more equipment to buy, install, clean, fix, upgrade and take up shop space. Brushing on finishes is simple and underrated, IMO – but doing it well and fast is a skill.
How you prepare your surfaces (sanding) before staining is very key – there is much necessary reading to be done on this topic unless you’re already ‘semi-pro’ at this.
With tighter grains like maple and birch plywood faces, I find water-based stains reveal the grain with very slightly more clarity and definition vs. oil stains – the best being DYE-based stains (you have to mix these yourself). But high-quality penetrating oil stains (not big box store big brand stains) can work pretty much just as well. Oak is hard but has an ‘open grain’ – so both water and oil based stains will work equally fine.
You can apply water-based finishes on dried oil stained surfaces, and vise-versa, generally.
And do your stain and finish samples first – sometimes they will reject your initial assumptions.
Good luck. Look forward to your posted finished AV centre pictures!
19627 posts in 2097 days
#7 posted 06-26-2013 11:13 PM
I vote oil based stain and brushed on water based poly. I like to use foam brushes.
redSLED
#8 posted 06-27-2013 02:25 AM
^ Big thumbs up on using foam brushes for clear coating. For carved/curved pieces and turned legs, bristle brush overrules foam brush.
View bondogaposis's profile
bondogaposis
5155 posts in 2591 days
#9 posted 06-27-2013 03:11 AM
I’d use General Finishes, SeaL A Cell and Arm R Seal. Wipe on couple of coats and you are done.
-- Bondo Gaposis
View BilltheDiver's profile
BilltheDiver
260 posts in 3126 days
#10 posted 06-27-2013 02:11 PM
My favorite finish on red oak is the classic amber shellac. Dries in minutes and you can apply furniture wax with 0000 steel wool to give it a totally smooth and lustrous finish without being too glossy. It’s also very easy to apply.
-- "Measure twice, cut once, count fingers"
View Logan Windram's profile
Logan Windram
347 posts in 2702 days
#11 posted 06-27-2013 09:34 PM
If the project is going to be on the darker side, I would suggest oil based stain and wipe on poly…. and as beginner, you almost can’t mess it up!!! LOL… a few thought. Oil based stains, just remember to wipe off and on oak if you are not filling the grain, watch for bleeding (stain oozing out after you have wiped, and during the drying process)- you can buy wipe on poly, or mix your own with varnish and a thinner- same thing, just remember to wipe on and off until you have the build you want.
Here the issue with water based stuff- watrr based stain and dye dry faster, especially dye (which I almostuse exclusively) so you have to wipe them off faster or they dry in streaks and clumps (it looks like crap)... its easy to clean and IMHO safer that oil, but you have to diligent. For Water Based Poly, like other have mentioned, it washes out darker woods… meaning it gives a slight haze to them that makes them look almost laminent… also, WB poly scratched and it less durable that Oil Based.. if you think this project is going to get bumped and banged, oil may be the way to go. What I LIKE about WB poly is it dries quickly so you can applly more coats in a quicker amount of time- cleanup is also a snap, soap and water baby!
  • also if you use a WB dye on a project and intend to use a WB poly, is will reactivate and smear the dye (you will see it on your brush)- so you will have seal it with bleached dewaxed shellac first. your other option is alchohol based dye, with I don’t think will be smeared by WB poly
I’d experiment- think of yourself as project finshing scientist… have fun with, expect to mess up a little, and remember you will look back on your first project in a few years and be amazed at how much you have learned since then
View Woodknack's profile
Woodknack
12469 posts in 2620 days
#12 posted 06-30-2013 12:48 AM
Rattle can acrylic lacquer.
View oldnovice's profile
oldnovice
7380 posts in 3608 days
#13 posted 06-30-2013 05:30 AM
I used to use the GF finishes but some of my favorites were not allowed in California so I use a lot of Minwax wipe on poly (which I have found to be very durable and good looking), Tung oil (Fornby’s was the best IMO), Deft spray lacquer (better than Rust-Oleum), and a variety of Waco oil finishes. All of these have served me well!
In general:
For knick-knacks and smaller items; lacquer, Tung oil
Furniture or other large pieces; wipe on poly, Watco Danish oil
I have tried the Minwax stain/poly combo but do not like it one bit.
View Bampei's profile
Bampei
48 posts in 3584 days
#14 posted 06-30-2013 06:24 AM
While not the cheapest solution, you might want to check out Festool’s Surfix system. Easy, lasting, and beautiful.
No muss, No fuss, No fumes, and no heavy smell. Complete system.
Here’s a video review by Peter Parfitt that shows the whole system and its uses. Worth watching!
-- "Winter is Coming"...Game of Thrones is BACK! Season 5
