HVLP Question
Forum topic by Gene Howe posted 06-25-2013 01:05 PM 971 views 0 times favorited 5 replies Add to Favorites Watch
View Gene Howe's profile
Gene Howe
9913 posts in 3299 days
06-25-2013 01:05 PM
I have an unused and inexpensive HVLP unit with which I want to spray Defthane clear.
Are their any precautions I should be aware of? Will it need to be thinned?
Thanks, folks.
5 replies so far
View Earlextech's profile
Earlextech
1160 posts in 2561 days
#1 posted 06-25-2013 01:09 PM
Deft sprays great with HVLP, just make sure you stir it gently with a stick. Even if it sits in the gun for 15 minutes without spraying you will need to stir it again.
View jumbojack's profile
jumbojack
1673 posts in 2495 days
#2 posted 06-25-2013 04:32 PM
Gene, I will sometimes thin laquer 25% as it comes from the can (brushing laquer right)? For the firt two or three coats, then full strength. I am not real sure there is a lot of benifit, but I have been MORE than pleased with the result.
View clarkanderson12's profile
clarkanderson12
1 post in 1667 days
#3 posted 06-25-2013 04:38 PM
thanks for the post
-- clark
View pintodeluxe's profile
pintodeluxe
5544 posts in 2684 days
#4 posted 06-25-2013 05:02 PM
I have had good luck with Deft Poly sprayed with a gravity feed HVLP gun.
With a 1.5 mm nozzle set, I sprayed the poly straight out of the can. You can thin it, but with my equipment I didn’t need to.
Gene Howe
#5 posted 06-25-2013 11:29 PM
Thanks for the help guys.
